Is there a way to scan for null or inserted frames in Virtualdub?
Results 1 to 9 of 9
If the capture was made with VirtualDub, Go -> Next drop frame which is Shift+] i.e. the } character. This will jump to frames that were marked as Inserted in the Capture mode. In the status bar with the frame # & timecode they will be marked with [D] instead of [K].
I don't know whether this will detect what Lagarith calls Null frames. And captures made using other software may or may not mark inserted frames the same way.
I don't know why the "dub" mode of VDub uses different terminology than the Capture mode. When you open a capture, there is no way to find the locations of what the Capture mode actually refers to as Dropped. Those frames are completely missing from the output file. -
I have an AmaRec capture that I labelled in the filename with +15f, and I can indeed count all 15 using Shift+].
An AVISynth script can easily find exact duplicates. You simply use one of the YDifference functions, and when they return zero, you know you have a duplicate.
This script replaces each duplicate with a new frame that is synthesized from the first frame prior to the duplicate:
Code:function filldrops (clip c) { super=MSuper(c,pel=2) vfe=manalyse(super,truemotion=true,isb=false,delta=1) vbe=manalyse(super,truemotion=true,isb=true,delta=1) filldrops = mflowinter(c,super,vbe,vfe,time=50) fixed = ConditionalFilter(c, filldrops, c, "YDifferenceFromPrevious()", "lessthan", "1.1") return fixed } -
progressive scan 29.97 frames per second MP4 to DVD
By ThisIsMyUserName in forum Video ConversionReplies: 1Last Post: 24th Jul 2016, 04:53 -
Virtualdub Capture: Inserted frame every 41st frame when capturing
By sventamyra in forum Capturing and VCRReplies: 14Last Post: 20th Apr 2016, 09:21 -
VirtualDub Neat Video scan type question
By kodec in forum RestorationReplies: 2Last Post: 1st Nov 2014, 08:12 -
VirtualDub Inserted Frames
By Ozzapoo in forum Capturing and VCRReplies: 1Last Post: 22nd Jan 2014, 20:42 -
Creating a Batch to Scan Multiple Video Streams for Errors with VirtualDub
By Ancalagon in forum ProgrammingReplies: 1Last Post: 20th Apr 2013, 16:06
