All I'm trying to do is change the aspect ratio of an .avi that was created using a video joining program, something that has worked dozens of times before without any problems. WHY is virtualdub suddenly giving me this message every time I try to save it?
requested frame not found; next valid frame = (number that's different every time the message appears)
Before you converted the same video or different video?
Looks like you are using my input driver plugin, the message may indicate corrupt index or some weird frame rate.
With particular file you may have better luck with internal "audio/video" driver. -
DaneClark-Next time you open a thread please put in a more descriptive title rather than 'why is this' so more people will help you.
Do you only want to change the aspect ratio or are you converting it for other reasons?
MPEG4 Modifier
Mind you it should work perfectly fine when playing the AVI on a PC, but hardware player support for AVI aspect ratios (AVIs without square pixels) might be a different story.
Virtualdub Capture: Inserted frame every 41st frame when capturing
By sventamyra in forum Capturing and VCRReplies: 14Last Post: 20th Apr 2016, 09:21 -
HandBrake giving me variable frame rate when I asked for constant
By Bruce Wayne in forum Video ConversionReplies: 4Last Post: 18th Apr 2016, 15:07 -
DV50 not found error in Virtualdub
By Wilykit in forum Video ConversionReplies: 3Last Post: 13th Mar 2016, 01:21 -
No audio decompressor could be found using VirtualDub
By dapster in forum Newbie / General discussionsReplies: 22Last Post: 6th Jun 2015, 05:25 -
VirtualDub - No audio decompressor could be found.
By kelemvor in forum Video ConversionReplies: 25Last Post: 24th Jan 2013, 17:36
