Hi!
Could you please help me in choosing all needed lens (the best ones) for my SONY A7S for shooting a video like this: https://vimeo.com/132187820
I would be very grateful for every advice.
It always depends on the kind of shots (and effect) you want to achieve.
If you literally want somethings that match your example, you will certainly want primes over zooms, as hardly any of those shots are zoom shots plus the bokeh looks more like primes would create.
Those shots are often short depth of field, so you would need fast lenses (low/wideopen maximum fstop). Most of the shots tend to the telephoto so you would want to favor that end of the range (70mm, 105mm, 200mm...).
The BEST cinematic lenses are NOT Sony lenses, nor with Sony mounts, so you would need to look at lenses that have a PL mount and then get a PL to Sony adapter ring.
Contact Lenses that takes videos and photos
By TreeTops in forum Latest Video NewsReplies: 2Last Post: 3rd May 2016, 15:38 -
The Rokinon 50 and 85 cine lenses
By newpball in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Jul 2015, 15:03 -
Choosing USB TV Tuner
By nijuuf in forum Newbie / General discussionsReplies: 9Last Post: 9th Aug 2014, 02:34 -
Issues with telephoto, wide-angle lenses
By brassplyer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 8th May 2014, 17:25 -
choosing a new laptop
By vhelp in forum ComputerReplies: 28Last Post: 22nd Sep 2012, 19:12
