  1. Hi, in case you miss the important Passkey update, I post it here.
    New feature named BDFix is added in Passkey. It can fix the playback problem of some Blu-ray ISO files and folders made by some 3rd party software, AnyDVD for example, because of their inability to remove certain protections, such as the Screen Pass, etc.
    The inability to tackle such obstacles, in other words, to remove the Screen Pass protection, Region Code, etc, will thus cause certain serious playback issues, such as black screen, or picking up the wrong playlist, when trying to playback the Blu-ray ISO files or folders made by those decrypting tools. With Passkey for Blu-ray, this playback issue can be fixed by the BDFix feature in around one minute, actual speed may vary on different sizes of the sources and your internet speed. All users need to do is to load the Blu-ray ISO file or folder into Passkey, and then click the Fix Blu-ray tab from the contextual menu to fix the problematic ISO file or folder. Once the fixing process gets finished, then users should no longer have any problem playing back the movies.
    You can download the lastest Passkey version and learn more at passkey webpage: http://www.dvdfab.cn/passkey-for-blu-ray.htm
  2. Originally Posted by DVDFab Staff View Post
    Huh?
    AnyDVD changelog...
    8.0.3.0 2016 06 22
    - New (Blu-ray): Improved ScreenPass support
    7.6.9.3 2016 03 25
    7.6.9.2 2016 03 20
    - New (Blu-ray): Support for new ScreenPass version as found on
    Mockingjay, Part 2, US
    etc.
    Such as? List everything "etc." applies to...
  3. Originally Posted by mike20021969 View Post
    Using DVFab's new Cloud Decryption, currently it can correct the failures of Region Code removal, incorrect playlist identification and faulty Screen Pass protection removal on Blu-ray.
  4. DVDFab BDFix has successfully solved the black screen issue on John Wick 2, which is still a big problem for Anydvd.
    If you are still upset about the John Wick 2 play issue, try DVDFab Passkey for Bluray. BDFix in it will be helpful.
