welp, I guess I've hit a roadblock. I'm trying to get 10-bit color to display correctly in my collection of hi10p videos on my media pc. I'll start with my config:
PC: i3 dual core, 8gb ram, gtx 560 ti
OS: Windows 10 64-bit Creators Update
GPU Driver Version: 382.33
Output: HDMI (direct to TV)
TV: Sharp LC52LE825U (Sharp Aquos Quattron 52 inch) - set to standard with all effects turned off
Nvidia CP: 1080p @60hz, truecolor(32-bit), RGB, 12BPC, full dynamic range
Media Playback: Potplayer 64-bit + MadVR (set to 10 bit under madvr>devices>Properties, colorspace set to auto)
when I try to change colorspaces, only yv410 4:4:4 shows 10-bit when it press ctrl+J. If I select auto, it shows NV12 8 bit, and RGB32 shows RGB32 8 bit. all colorspaces show visible banding in the 16 bit PNG test pattern I found from google. when compared to the PNG loaded in whatever win10's photo viewer app is called (probably just "photos") it looks noticeably different than in potplayer, though it too shows banding, perhaps because of DWM (or so I've read in other threads, though they may not have been talking about win10).
First, I'd like to verify that my TV is truly a 10 bit panel, or if it just accepts 10 bit input, I could not find such information online. If it really is a 10 bit display, how can I fix my issue?
As well, I'll be happy to provide any other details/specs if required,
Thanks!
PS: can't wait to buy a 4k 10 bit monitor for my gaming system!
Results 1 to 1 of 1
PotPlayer - How to use MadVR?
By jackuars in forum Software PlayingReplies: 49Last Post: 3rd Dec 2021, 18:20 -
Open MadVR in PotPlayer 32 bit
By loninappleton in forum Software PlayingReplies: 9Last Post: 10th Apr 2017, 00:19 -
Poor reds in Potplayer with MadVR
By alex30 in forum Software PlayingReplies: 28Last Post: 18th Sep 2015, 03:31 -
PotPlayer / madVR upscaling only width?
By skribby in forum Software PlayingReplies: 4Last Post: 22nd Apr 2015, 13:46 -
Issue with MadVR in Potplayer
By wolfman2791 in forum Software PlayingReplies: 3Last Post: 26th Feb 2014, 10:50
