  1. Member brassplyer's Avatar
    Apr 2008
    Just got a set of the complete original Star Trek series. There's an option to switch between the original SFX and updated SFX using the angle button when a movie camera icon pops up in the upper right corner. My LG BP-200 Blu-Ray player doesn't have an angle button. That icon is annoying - anyone know if there's a way to kill it?
    Feb 2006
    Did you look in the Bluray player settings menu ??
  3. Member brassplyer's Avatar
    Apr 2008
    Don't find anything related to this. I see there's a command for angle under Info Menu but nothing about disabling the icon.
    Feb 2006
    What model bluray player do you have ? ?
  5. It's not an option on the Special Features or Language options of the Bluray's Menu by any chance? Failing that, I know it's not the same, but the green button on my Freeview PVR's remote will usually remove any on-screen messages about the red button or asking if I want to schedule a reminder? Just a thought.
  6. Member brassplyer's Avatar
    Apr 2008
    what model bluray player do you have ? ?
    lg bp200
