I'm curious as to whether, after telecine, the video before color correction tends to be more or less saturated than the final product?
What colour correction are you referring to? I assume it's the combination of DGIndex and ColorMatrix, but 99.9999999999999% of the time it's probably doing nothing.
The difference is rec.601 colorimetry (SD) vs rec.709 (HD). If it's wrong reds can look a bit darker and blue and green a bit brighter, or the other way around red can look a bit more orange and blur and green get darker, but the difference is generally pretty subtle.
To see the difference try to find a scene with as much red as possible as it tends to be more noticeable.
ColorMatrix(mode="Rec.709->Rec.601", clamp=0)
or
ColorMatrix(mode="Rec.601->Rec.709", clamp=0)
If that's not what you're referring to, I'm not sure what you mean. Telecine shouldn't effect the saturation.
Saturation in color correcting - how much is too much? [Lengthy question]
By CZbwoi in forum RestorationReplies: 7Last Post: 29th Oct 2016, 08:01 -
Avisynth filters for brightness, color & saturation and sharpening
By yukukuhi in forum EditingReplies: 6Last Post: 6th May 2016, 15:27 -
Tweak Saturation Causing Color Issues
By killerteengohan in forum RestorationReplies: 42Last Post: 8th Nov 2014, 21:44 -
Weird color saturation when connecting dvd player to tv with hdmi cable
By bigmack3000 in forum DVD & Blu-ray PlayersReplies: 22Last Post: 15th Sep 2014, 12:20 -
Night video to DVD (improve contrast and saturation)
By cd090580 in forum Video ConversionReplies: 18Last Post: 24th Aug 2012, 11:06
