  1. Could someone recommend a 4K codec to use? I am exporting exr sequence files, rendered out of a 3D application, and I need to generate an intermediate file for further editing. I am using premiere pro cs6.
    I've tried utvideo, but go color banding (maybe I didn't set up the correct settings)
    I've also tried the cineform codec (by installing the GoPro Studio) and I get an error on export stating "CFRenderProc has stopped working"
    If one of the top codecs is the one to use, I'll keep messing with them to fix the issues.
    If cineform, does it matter between avi or mov? I'm on win 7 64 bit. TIA
    Aug 2010
    San Francisco, California
    You might try Avid's DNxHD or DNxHR. I try to stay away from MOVs on Windows because Explorer insists on scanning them and bogs down the processor. I thought CineForm was supposed to be hot stuff right now; too bad it's bombing out on you.
  4. I find Grass Valley HQX a useful intermediate for editing 4K.
    Similar quality to Cineform .. and free - which is useful !
  5. Another option is to use them natively; the old proexr plugin has been made free this year
    http://www.fnordware.com/ProEXR/
    If the goal was editing/performance, you can use a proxy workflow and still swap to the native files
  6. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Ut Video is a lossless codec, so anything you feed into should be 100% retained. Maybe you need to move up to 10-bit or maybe move above 4:2:0 when working with your 3D creations.
  7. Originally Posted by KarMa View Post
    100% retained at the same bit depth and color model
    But EXR is typically 32bit (or sometimes 16bit) RGB. You can even get banding converting to 10bit RGB. It's highly dependent on the type of dithering for bit depth conversion
  8. I agree with pdr, no need to gen an intermediate file, just edit the EXR sequence.
