Hello, dear all.
CCleaner is a program that I use in my PC's.
---> http://www.piriform.com/ccleaner
But, I heard that CCleaner does not work so well on Windows 10. Does it true? Or it's developers have fixed that?
For windows 10 which other program do you point that can do all thing that CCleaner does? Any good freeware / portable that can do it too?
I mean: cleaning cookies, the registry, the history, etc.
Thanks.
Best regards.
devil ( johner)
You'll find many opinions on this, in the end you have to use your judgement and decide for your self.
https://www.tenforums.com/software-apps/2185-ccleaner-windows-10-a.html
https://www.reddit.com/r/Windows10/comments/3y84al/can_someone_explain_why_ccleaner_has_gotten_such/ -
Dont know about CCleaner on Win10 but this is what i use and its very through in its spring cleaning,
updated very often, It can also perform a smart scan and overwrites only what HD sectors it need to,
Note i`m nothing to do with the developer.
http://privazer.com/ -
I've been using CCleaner on Windows 10 since before Win10 was officially released - including the registry cleaning part - and have had no issues with it. If you're nervous about using the registry cleaning part, then don't use it. I don't let it run in the background or monitor whatever it says it's monitoring, I'll run it as and when I choose to, as I have since I first discovered CCleaner back when the first 'C' still had three other letters between it and the second 'C'.
In my experience, CCleaner has worked without issue under Windows 10 from Threshold 2 (1511) through Creators Update (1703).
CCleaner (Crap Cleaner) is a freeware system optimization, privacy and cleaning tool. It removes unused files from your system allowing Windows to run faster and freeing up valuable hard disk space. It also cleans traces of your online activities such as your Internet history. Additionally it contains a fully featured registry cleaner.
https://www.piriform.com/ccleaner
AvsPmod - can't get it to work properly
By pooksahib in forum Video ConversionReplies: 9Last Post: 5th Sep 2021, 06:33 -
I cannot convert my old tv series files to work properly on a Samsung HDTV
By TV Addict in forum Video ConversionReplies: 8Last Post: 30th Mar 2017, 18:55 -
ADVC Mini doesn't work properly
By keyboardboy in forum MacReplies: 32Last Post: 1st Dec 2016, 23:23 -
Windows Movie maker not properly outputting movies in 16:9
By XMrNiceguyX in forum Video ConversionReplies: 2Last Post: 11th May 2013, 13:21 -
VobSub needs admin rights to work properly?
By Gew in forum DVD RippingReplies: 3Last Post: 21st Oct 2012, 15:10
