I AM USING WINDOWS XP AND I HAVE A DVD ROM AND A CD WRITER. I HAVE BEEN TRYING TO MAKE VCD'S FROM DVD MOVIES AND FROM DOWNLOADED MOVIE FILES. I CANT GET ANYTHING TO WORK WITH WIN XP. CAN SOMEONE PLEASE TELL ME SOME SOFTWARE I CAN USE WITH WINDOWS XP. THANK YOU VERY MUCH.
Thank You in advance for any advice I may receive
DrNachi -
More info would be useful. Are you using a 3rd party burner s/w such as Nero ? Have you downloaded the latest drivers for XP? Have you downloaded the necesary codecs for the downloaded movies?
I was using clone cd , but i will get whatever s/w might be compatible with win xp to use for this. i am not sure about the codecs. i can watch the d/l movies with media player and they work just fine. when i look up the file extension it just says movie file. i know this isnt a lot of info but im pretty new to all of this. i have tried some freeware/demo programs like easydivx,directdvd and dupdvd but they all have some aspi layer problem. either winxp doesnt use an aspi layer or its incompatible.
thanks for the reply
DrNachi -
There are various products to use but the most popoular are the freeware ones - TMPGenc for encoding the MPEG files and VCDEasy for burning the VCD on your writer.
I personally haven't used VCDEasy but I have read good things about it and it is FREE. I use TMPGEnc v.2.53 to encode my home movie files to MPEG (MPEG1s for VCD and MPEG2s for SVCD) and I burn with Nero version 5.5.8 which is one of the strongest burners on the market - you can download a demo version of Nero from www.ahead.de. There are links on this site for downloading TMPGenc and VCDEasy. I have just upgraded to XP Pro and Nero and TMPGenc work fine.
I hope this helps.
Problem with subtitles (Win 7 x64)
By Laxus in forum SubtitleReplies: 2Last Post: 27th Aug 2010, 04:46 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 02:12 -
Reinstall Win Xp/Video Drivers problem
By Soixante in forum ComputerReplies: 6Last Post: 9th Nov 2009, 08:02 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 22:51 -
Hauppauge Win TV Card problem.
By seymoria in forum Capturing and VCRReplies: 5Last Post: 25th Jul 2008, 16:30
