Hello there, i wanted to know if there is possible to copy audio through avisynth script+ffmpeg encoding. When i load script in FFMpeg it show me audio input of "pcm_s16le" when the original source is AAC, so i dont know exactly where it's being converted from AAC to pcm_s16le and if i can avoid it and copy it directly without reeconding the audio.
avs frameserves uncompressed audio and video, so you can't "stream copy" from avs
The solution is to use 2 inputs and -map . video with the avs, audio copied directly from the actual source
-map 0:0 means first input, first stream . -map 1:1 means 2nd input 2nd stream (starting from zero, so track 1 is usually the audio)
eg. it will look something like this
Code:ffmpeg -i input.avs -i input.mp4 -map 0:0 -map 1:1 -c:v libx264 -c:a copy output.mp4
Thanks for the information. I'm using batch encoding, can this work in that way too?
Anything that can be done through CLI should be possible with the proper batch script.
Audio speed distorsion when using an avisynth script
By kaskaļ in forum Newbie / General discussionsReplies: 5Last Post: 31st Jan 2017, 08:33 -
Need help with ffmpeg script to batch convert audio in MKV files
By mikeveli20 in forum AudioReplies: 5Last Post: 18th Nov 2016, 13:21 -
Help with avisynth script please - mpeg audio
By pooksahib in forum Video ConversionReplies: 6Last Post: 24th Oct 2016, 10:54 -
Avisynth Script audio problem
By Mr_Flintstone in forum Video ConversionReplies: 12Last Post: 19th Apr 2014, 23:01 -
Encoding AAC Audio from an Avisynth script
By pengy in forum AudioReplies: 3Last Post: 6th Sep 2012, 13:09
