I saw a very nice Youtube video of BIOS settings. It was made whilst using AVerMedia Live Gamer Portable (LGP).
A big shortcoming on my side, but to be honest until today I never heard of this possibility.
(Note: while the product name includes 'gamer' - I myself don't play games).
From what I understand the connection goes as follows:
Videocard->HDMI cable->LGP
LGP->HDMI cable->Monitor
HDMI connector at the back of the monitor is a bit complicated to reach, hardly visible, monitor should be turned over.
Wonder, if I don't use LGP, should I do the plugging and unplugging session each time?
BTW, though this AVerMedia Live Gamer Portable (LGP) really looks nice and handy, are there any other products with
similar features and quality?
Not sure I understand, since it sounds like you've found a device that will do it. But I've done it with the Startech USB3HDCAP. It has an option than allows it to automatically scale any of its supported incoming resolutions to your desired capture resolution, so you don't have to change any settings to capture the 640x480 BIOS and the rest of the bootup to 1920x1080 for example.
Hi there, thanks for getting on this.
You may wish to do a Google search on: "asus avermedia live game portable youtube BIOS" (without quotes).
You will see quite a number of videos of BIOS screens recorded using the LGP.
However, as said, if the -only- purpose is to record BIOS screens, then the LGP is a kind of 'overkill'.
Likely the product is meant for gamers(?) and so it has multiple uses.
In my case, I don't play games, to it is bit expensive. Therefore I am looking for alternatives...
Just now(!) so I don't have it worked out and don't know it will work..
I have a Sony Cybertshot DSC100M3 - it has a HDMI connector.
I was wondering about the following.
buy a Micro HDMI to DVI-D Cable
connect DVI-D to videocard (currenly monitor is using the HDMI output)
then..
maybe(!) it will record the BIOS screens as well:
the camera can playback images and video thru the HDMI connector, but it can also record.
again, I don't know.
the idea is that in this case the camera is doing the same as the LGP but using a different output (DVI-D)
however, maybe there are easier solutions..
https://www.dpreview.com/files/p/articles/9874469037/images/right.jpeg
No. All you can do with a camera is take a picture of the screen in the usual way. An HDMI port is a one-way connection. The HDMI connection on a camera can only be used to display images or video on a connected TV or monitor. It cannot be used to record from a connected video source.
One of the connections in your photo is a USB port, the other is HDMI.Last edited by usually_quiet; 26th May 2017 at 13:06.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Sorry for the delay.
Thanks a lot. I have been searching for a solution (like search for: HDMI in recorder)
but bottom line probably there is no 'easy' one, sadly enough.
Except for buying hardware that is.
Anyway, thanks again.
“ No NVENC capable devices found” with ffmpeg for screen capture and RTP
By ThadeuMelo in forum Capturing and VCRReplies: 1Last Post: 22nd May 2017, 18:43 -
Game HD capture devices (Elgato, Avermedia, Hauppage) for vhs capturing
By videorecover in forum Capturing and VCRReplies: 4Last Post: 7th Jan 2016, 18:48 -
Recording Phone Calls, Digitally – Suggestions?
By Jenny in forum AudioReplies: 7Last Post: 26th Feb 2015, 11:16 -
Looking for recorder capable of recording line level (+4dbu) from mixer.
By techspark in forum AudioReplies: 7Last Post: 22nd Oct 2013, 13:33 -
Suggestions for specific recording situation
By Tommy2013 in forum Newbie / General discussionsReplies: 7Last Post: 21st Mar 2013, 13:13
