Hi all,
First of all, I'm an absolute newbie to this forum and DVD authoring in general.
Since Adobe pulled the plug out of Creative Suite, there's no way for me to download Encore anymore. I used it to make basic DVD's that start playing immediately when inserted.
I'm in a DVD-Lab Pro trial at the moment. It seems great software, but there are a lot of greyed out options. I can't even hit the undo/redo buttons.
I tried to see if this is just because I'm in a trial, so I cracked the software but there was still no possibility for me to hit the undo button.
I'm exporting from Premiere Pro, so I'm getting an .m2v file and an .ac3 file.
Also, is there any other DVD authoring software in which you can do things manually? I couldn't really find anything besides DVD-Lab.
What's going on here?
Regards,
Sander
Hi,
Please avoid to speak about cracking softwares, authors work very hard developing and coding softwares, so if you like them try them and buy them.
Have a look at MPEG Video Wizard DVD 5.0 or Womble EasyDVD (http://www.womble.com).
Cheers.Last edited by OkeN; 22nd May 2017 at 19:36.
I was under impression that undo redo is not working with DVDLab Pro, there is no need to have it anyway, you just delete particular part, code, something, replace it. DVD authoring construction is not a linear process, you can start from whatever end you wish, or you can replace or change parts you do not like.
If you do not need menu, you do not need DVDLab Pro, you can just mux VIDEO_TS with Muxman, then burn it with ImgBurn.
Or use command line to create VIDEO_TS:
where your_project.mxp is text file , you just correct those three bolded lines, paths for m2v, ac3 and aspect ratio (4:3 or 16:9) and it looks like that for example:Code:"Muxman.exe" "your_project.mxp" -d "C:\OUTPUT" -l "C:\OUTPUT\muxman.log" -run
(btw, muxman recognizes that PAL or NTSC m2v stream and creates DVD as such, no need to specify it anywhere, it even checks that stream for DVD compatibility)
Code:Section=Settings { Destination Folder= Item=Palette { Name=DefaultPalette Color 0=0,0,0 Color 1=255,0,0 Color 2=0,255,0 Color 3=255,0,0 Color 4=0,255,0 Color 5=0,0,0 Color 6=0,0,0 Color 7=0,0,0 Color 8=0,0,0 Color 9=0,0,0 Color 10=0,0,0 Color 11=0,0,0 Color 12=0,0,0 Color 13=0,0,0 Color 14=0,0,0 Color 15=0,0,0 } } Section=Content { Item=Segment { Name=Segment_1 Display Mode=16:9 Item=Video Stream { Item=Video Play { File=C:\my_video.m2v Duration=Actual } } Item=Audio Stream { Stream Number=1 Language=en Language Extension=1 Item=Audio Play { File=C:\my_audio.ac3 } } Item=Scene List { Item=Scene { Name=Segment_1_scn1 Scene Time=00:00:00:0 Uop=0 } } } } Section=Navigation { Item=First PGC { Name=FP Menu ID=No Menu Uop=00000000 PG Playback Mode=Sequential Playback Repeat Times=0 PGC Still Time=0 Palette=DefaultPalette Item=Pre Commands { Mov GPRM0, 1 JumpSS TitleMenu } Item=Post Commands { } Item=Cell Commands { } Item=Program List { } } Item=VMG { Item=Language { Name=VMGM Language=en Item=PGC { Name=MainMenu Menu ID=Title Menu Uop=000C03E3 Next PGC= GoUp PGC= PG Playback Mode=Sequential Playback Repeat Times=0 PGC Still Time=0 Palette=DefaultPalette Item=Pre Commands { Mov GPRM1, 1 if ( GPRM0 == GPRM1 ) JumpTT TitleSet1_Title1 Mov GPRM1, 2 if ( GPRM0 == GPRM1 ) Exit } Item=Post Commands { } Item=Cell Commands { } Item=Program List { } } Item=PGC { Name=MainJumpPGC1 Menu ID=No Menu Uop=000C03E3 Next PGC= GoUp PGC= PG Playback Mode=Sequential Playback Repeat Times=0 PGC Still Time=0 Palette=DefaultPalette Item=Pre Commands { Mov GPRM2, 1 if ( GPRM1 == GPRM2 ) JumpTT TitleSet1_Title1 Mov GPRM2, 2 if ( GPRM1 == GPRM2 ) LinkPGCN MainMenu } Item=Post Commands { LinkPGCN MainMenu } Item=Cell Commands { } Item=Program List { } } } } Item=VTS01 { Item=Language { Name=TitleSet1M Language=en Item=PGC { Name=TitleSet1Menu Menu ID=Root Menu Uop=000C03E3 Next PGC= GoUp PGC= PG Playback Mode=Sequential Playback Repeat Times=0 PGC Still Time=0 Palette=DefaultPalette Item=Pre Commands { JumpVTS_TT TitleSet1_Title1 } Item=Post Commands { } Item=Cell Commands { } Item=Program List { } } } Item=Title { Name=TitleSet1_Title1 Uop=0 Item=PGC { Name=TitleSet1_Title1_PGC1 Menu ID=Title Entry Uop=0 Next PGC= Prev PGC= GoUp PGC= PG Playback Mode=Sequential Playback Repeat Times=0 PGC Still Time=0 Palette=DefaultPalette Item=Pre Commands { } Item=Post Commands { Mov GPRM0, 2 CallSS RSM=1, TitleMenu } Item=Cell Commands { } Item=Program List { Item=Program { Name=TitleSet1_Title1_chapter1 Item=Cell { Name=TitleSet1_Title1_cell1 Linked Scene=Segment_1_scn1 Command= Cell Still Time=0 VOBU Still Flag=False Access Restriction Flag=Permitted Cell Type=0 Seamless Flag = Default } } } } Item=Part of Title List { Item=TitleSet1_Title1_chapter1 } } } }Last edited by _Al_; 22nd May 2017 at 22:37.
DVD LAB PRO 2.52 Transitions
By litost88 in forum Newbie / General discussionsReplies: 4Last Post: 12th Apr 2016, 14:56 -
[DVDLAB PRO] Help, I need to change region DVD in DVD LAB Pro
By kirous in forum Newbie / General discussionsReplies: 25Last Post: 16th Jul 2015, 08:07 -
DVD Lab Pro help
By b2kguga in forum Newbie / General discussionsReplies: 1Last Post: 25th May 2015, 15:09 -
Custom project settings greyed-out in Premiere Pro CS3
By Xoanon in forum EditingReplies: 3Last Post: 2nd Jun 2013, 18:21 -
I Need Help with DVD Pro lab
By derr_eng in forum Authoring (DVD)Replies: 20Last Post: 31st Aug 2012, 22:09
