I´m trying to stream my Desktop with RTP using ffmpeg.
libx264 seems to work fine. But I would like to test the performance of a hardware accelerated codec.
Code:ffmpeg -re -f dshow -i video="screen-capture-recorder" -vcodec libx264 -tune zerolatency -preset ultrafast -an -f rtp rtp://192.168.0.1 The NVENC codec works fine in other situations like thisHowever this command doesn´t workCode:ffmpeg -y -rtbufsize 2000M -f gdigrab -framerate 60 -offset_x 0 -offset_y 0 -video_size 1280x1080 -i desktop -c:v nvenc -preset:v fast -pix_fmt nv12 out.mp4 The Codec also apears in the list of available codecs.
My machine is a Windows 10 with GTX 760Code:ffmpeg -re -f dshow -i video="screen-capture-recorder" -vcodec nvenc -preset llhq -an -f rtp rtp://192.168.0.1
First verify correct name for codec
and later verify codec capabilitiesCode:ffmpeg -encoders
Seem your card use GK104 https://en.wikipedia.org/wiki/Nvidia_NVENC#First_generation_.28Kepler.29 - you should use codec likeCode:ffmpeg -h encoder=
Code:-c:v nvenc_h264
Unterstanding how to use ffmpeg nvenc.
By Selur in forum Newbie / General discussionsReplies: 14Last Post: 25th May 2017, 19:29 -
faster ffmpeg video/audio encodes for nvenc/loudnorm ?
By hydra3333 in forum Video ConversionReplies: 1Last Post: 14th Jan 2017, 05:39 -
Use NVENC & FFMPEG on Premiere Pro
By haneef95 in forum EditingReplies: 3Last Post: 7th Nov 2016, 09:31 -
Blackmagic UltraStudio SDI & ffmpeg + Nvenc
By vedroide2e4 in forum Video ConversionReplies: 25Last Post: 7th Apr 2016, 01:39 -
ffmpeg with '--enable-nvenc'
By Selur in forum Video ConversionReplies: 1Last Post: 13th Jan 2015, 06:45
