  1. Code:
    Mpeg2Source("I:\VIDEO_TS.d2v", CPU2="ooooxx")
    va = fa()
    vb = fb()
    vk = fk()
    ReplaceFramesSimple(va, vb, mappings="[33951 34081][34501 34783][35214 35349][35956 36318][39113 39152][40699 40771]")
    ReplaceFramesSimple(va, vk, mappings="[43678 46224]")
    return(last)
    function fa(clip C)
    C
    TFM()
    ColorMatrix(mode="rec.601->rec.709")
    ColorYUV(cont_y=15, cont_u=80, cont_v=35,gamma_y=-35)
    McTemporalDenoise(settings="Medium")
    McTemporalDenoise(settings="High")
    Hysteria(strength=1.0, maxchg=30,lowthresh=4)
    nnedi3_rpow2(2, cshift="spline36resize", fwidth=1280, fheight=720)
    Sharpen(0.7)
    Hysteria(strength=1.0, maxchg=35,lowthresh=2)
    Dehalo_alpha(rx=3, ry=3, darkstr=0.4, brightstr=0.4)
    Blur(0.6)
    aWarpSharp(depth=6)
    return Last
    function fb(clip C)
    C
    QTGMC(FPSDivisor=2)
    Sharpen(0.7)
    Blur(0.6)
    aWarpSharp(depth=6)
    return Last
    function fb(clip C)
    C
    QTGMC(FPSDivisor=2)
    Sharpen(0.7)
    Blur(0.6)
    aWarpSharp(depth=6)
    return Last
    function fk(clip C)
    C
    QTGMC(FPSDivisor=2)
    return Last
    it doesnt apply the QTGMC at the targeted sections ... it just uses the first script (i use it it to fix interlacing)
  2. ReplaceFramesSimple() doesn't modify the baseclip, it returns a clip. You need to do:
    va=ReplaceFramesSimple(va, vb, ....)
