I have an avi file and an srt for it. But the srt starts at 40 seconds in and the movie at 2 mins 40 seconds because there is an introduction in the movie. Is it easier to cut off the first two minuts of the movie- what program- or edit the srt. How can the srt be synced
Results 1 to 13 of 13
In many players you can change the delay on-the-fly.
If you do want to edit avi or srt editing the srt is easier. Open the srt in Subtitle Edit and click "Synchronization">"Adjust all times[...]". Then for all lines set 2 minutes, click "Show later" and save the new srt. -
Since a .srt file is just text it can be, relatively, easy to edit.
You can read here about the format of the file
https://matroska.org/technical/specs/subtitles/srt.html
In your case you would add 2 minutes on both time elements.
You can use Notepad or another text editor - just resave the file with the same name and .srt.
But are you really sure about these timings. Very odd to have this. (Unless someone edited the movie AFTER the subs were created) -
Subtitle Workshop can shift all subtitles temporally. But don't be surprised if there are other sync issues after shifting. Different sources often are different cuts of the movie, different running times (frame rates), etc.
If it is a text file, you should be able to open it in Excel, write a formula to add the needed time to achieve sync, and then save the file back out of Excel as a text file (or copy/paste into Notepad).
That worked pretty good thanks. Still some parts slightly out because the srt differs a little in wording to the movie in some places. He might say "i will go to the shop to get sweets" and the srt may have "i will get sweets" They are just examples not dialogue. It is as good as can be achieved with an old movie
Subtitling is restricted to a certain numbers of characters pr line.
They are supposed to stay on the screen long enough for the viewer to actually read them
So you'll never get an exact representation of a dialouge. -
I'd have to see an example of the timecode. In general, if the timecode is in A3 and the offset that you wish to add is in A1, then the formula for the new timecode (in B3) would be:
=A3 + $A$1
The formula gets more complicated for timecodes that are in minutes, seconds, and frames, since Excel native function don't understand that timecode.
The web site Mr Excel has an amazingly large number of answers to questions like this. -
SRT time codes are in hh:mm:ss.ms format.
Code:1 00:01:30,623 --> 00:01:32,090 Family's too late! 2 00:01:37,530 --> 00:01:39,498 - Flatline. - Tried how long? 3 00:01:40,200 --> 00:01:41,394 55 minutes.
ripped .srt out of sync with DVD
By gnomio in forum SubtitleReplies: 2Last Post: 6th Aug 2015, 15:11 -
Correct out of sync sustivles srt files? they fast.
By PedgeJameson in forum Video ConversionReplies: 3Last Post: 2nd Apr 2015, 07:59 -
looking for easyway auto-sync 2 srt files
By l_cabey in forum SubtitleReplies: 2Last Post: 16th Sep 2013, 13:05 -
AVI and SRT subtitles increasingly out of sync
By fiiido in forum SubtitleReplies: 27Last Post: 31st Jul 2012, 09:53 -
no subs on avi/srt with same name
By David Banner in forum Newbie / General discussionsReplies: 1Last Post: 24th Jun 2012, 19:36
