I want to set it back to predict left but no matter what I do, after I save it and reopen the dialog box to check it, it's always stuck back on predict median. Anything to do here? (VirtualDub, Win 7... )
And now on top of that I can't even direct stream copy the captured VHS Huffy, something i did 100s times before. It says something like
The source video stream uses a compression algorithm which is not compatible with AVI files. Direct stream copy cannot be used with this video stream
Anyone?
I have tried uninstalling and installing the kodec pack but nothing helps, all of the sudden nothing works as it had worked before. -
The second one sounds like you opened it with ffmpeg plugin. Try selecting "audio/video interleaved" when you open the file.
Thanks shekh, that was it... what have I don to change the default setting... Anyway, do you happen to know perhaps where to set it back as the default?
Maybe there is something to change permanently if you tick "ask for extended options", if that plugin is ffmpeginputplugin.vdplugin
Not sure what you have.
Help with detelecine settings: PAL DVD with scene-change field blending?
By U2Joshua in forum Video ConversionReplies: 9Last Post: 22nd Dec 2016, 22:00 -
Change regional settings
By Eseniloc in forum Media Center PC / MediaCentersReplies: 3Last Post: 6th Jan 2016, 16:41 -
How to change scanner settings
By jyeh74 in forum ComputerReplies: 7Last Post: 1st Jan 2015, 07:48 -
Conversion settings for Wondershare Converter; export settings for Pinnacle
By avz10 in forum Video ConversionReplies: 1Last Post: 19th Jul 2014, 12:41 -
How doI change region settings for Audiosonic DVD player KM3608N?
By Maurice X in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Jun 2013, 15:01
