Hi I have a 6.5 gb movie that has this drm encrypting it.
I got it from an Mpeg-DASH stream that was encrypted.
Anyway, I got the keys and the key id from the same site I got the video.
I was using Bento4 mp4decrypt and it decodes the movie without displaying errors but then the final product is still encrypted.
The key id looks like this:
cenc:default_KID="562386c1-854b-11e6-89af-842b2b5247fa"
and the keys look like this:
widevine: "EDEF8BA9-79D6-4ACE-A3C8-27DCD51D21ED",
playready: "9A04F079-9840-4286-AB92-E65BE0885F95"
Here is the readme from mp4decrypt:
And here is my syntax:Code:usage: mp4decrypt [options] <input> <output> Options are: --show-progress : show progress details --key <id>:<k> <id> is either a track ID in decimal or a 128-bit KID in hex, <k> is a 128-bit key in hex (several --key options can be used, one for each track or KID) note: for dcf files, use 1 as the track index note: for Marlin IPMP/ACGK, use 0 as the track ID note: KIDs are only applicable to some encryption methods like MPEG-CENC --fragments-info <filename> Decrypt the fragments read from <input>, with track info read from <filename>.
Thanks for anyone who takes a lookCode:mp4decrypt.exe --key 562386c1-854b-11e6-89af-842b2b5247fa:EDEF8BA9-79D6-4ACE-A3C8-27DCD51D21ED --key 562386c1-854b-11e6-89af-842b2b5247fa:9A04F079-9840-4286-AB92-E65BE0885F95 input.mp4 output.mp4Anyone know how to decrypt successfully?
Woohoo got the encryption to go away but the files are corrupt af and I can't listen or see them. Is there any way to get them to be viewable or am I hosed? From ffmpeg:
Code:C:\Users\Office\Desktop\Pioneers>ffmpeg -i vid.mp4 ffmpeg version 3.0.2 Copyright (c) 2000-2016 the FFmpeg developers built with gcc 4.9.3 (GCC) configuration: --enable-static --disable-shared --disable-ffplay --disable-ffs erver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtm p --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enab le-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target- os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config --bindir='/jenkins/workspace/FFmpeg - Win32/target' libavutil 55. 17.103 / 55. 17.103 libavcodec 57. 24.102 / 57. 24.102 libavformat 57. 25.100 / 57. 25.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 31.100 / 6. 31.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [h264 @ 02c71380] error while decoding MB 89 7, bytestream -26 [h264 @ 02c71380] concealing 7280 DC, 7280 AC, 7280 MV errors in I frame Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'vid.mp4': Metadata: major_brand : iso6 minor_version : 1 compatible_brands: mp42dashmsdhmsixiso6avc1isom creation_time : 2016-09-28 07:48:34 Duration: 01:54:56.51, start: 0.041711, bitrate: 8067 kb/s Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 8064 kb/s, 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc (defaul t) Metadata: encoder : AVC Coding At least one output file must be specified C:\Users\Office\Desktop\Pioneers>ffmpeg -i sound.mp4 ffmpeg version 3.0.2 Copyright (c) 2000-2016 the FFmpeg developers built with gcc 4.9.3 (GCC) configuration: --enable-static --disable-shared --disable-ffplay --disable-ffs erver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtm p --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enab le-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target- os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config --bindir='/jenkins/workspace/FFmpeg - Win32/target' libavutil 55. 17.103 / 55. 17.103 libavcodec 57. 24.102 / 57. 24.102 libavformat 57. 25.100 / 57. 25.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 31.100 / 6. 31.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [aac @ 006f1400] Sample rate index in program config element does not match the sample rate index configured by the container. [aac @ 006f1400] Remapped id too large [aac @ 006f1400] is not implemented. Update your FFmpeg version to the newest o ne from Git. If the problem still occurs, it means that your file has a feature which has not been implemented. [aac @ 006f1400] If you want to help, upload a sample of this file to ftp://uplo ad.ffmpeg.org/incoming/ and contact the ffmpeg-devel mailing list. (ffmpeg-devel @ffmpeg.org) Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'sound.mp4': Metadata: major_brand : iso6 minor_version : 1 compatible_brands: mp42dashmsdhmsixiso6avc1isom creation_time : 2016-09-28 07:48:38 Duration: 01:54:56.64, start: 0.000000, bitrate: 193 kb/s Stream #0:0(und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, 5.1, fltp, 192 kb/s (default) Metadata: creation_time : 2016-09-28 07:36:41 At least one output file must be specified
If the encyption is any frakking good, and it is, then of course you won't be able to decrpyt it.
How did you manage to get the Encryption Keys?
So far all I have seen with PlayReady is it's easy to grab the files just about any Videp Plugin Downloader in any Browser will do it but they are all AES encrypted w/o any keys.
Personally I want to strip the DRM from my Movie and TV Collection I legally purchased on Amazon but I have not been able to do anything except download useless files that would take 100 years to Brute Force the encryption
Looking for anyone with Google Widevine knowledge.
By cookeri6 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2017, 13:33 -
By cookeri6 in forum Video Streaming DownloadingReplies: 0Last Post: 15th May 2017, 12:45 -
How to strip Amazon DRM
By lordhutt in forum Video Streaming DownloadingReplies: 34Last Post: 3rd Sep 2014, 13:46 -
How to news strip in videos.
By chetan.saini in forum EditingReplies: 1Last Post: 28th Aug 2014, 06:21 -
DRM Removal Program to Remove iTunes DRM Protection
By Teac23 in forum AudioReplies: 1Last Post: 17th Dec 2012, 08:26
