Results 1 to 13 of 13
  1. What am I doing wrong? A setting? Different software?
  2. Ripped how? What if you play the rip in e.g. MPC-HC? What version of HandBrake? Activity log? Sample?
  3. Originally Posted by sneaker View Post
    Does not play in MPC-HC (downloaded the latest portable version and tried).
    Newest version of Handbrake
    Not sure how to create log.
  4. Here's a sample (the entire video is like this): https://www.youtube.com/watch?v=dUFWF4D5Keg
    Mar 2008
    You ripped this DVD? How?
    Could be something as simple as the copy protections have not been negated and your rip is garbage.
  6. That's what it looks like to me, too - that it wasn't decrypted. You can't just copy the VOBs over to the hard drive. The DVD has to be decrypted properly first.
    I don't use it, but Handbrake doesn't decrypt, does it? So, what, if anything, was used to transfer the DVD to the hard drive?
  7. Originally Posted by davexnet View Post
    I tried ripping with Handbrake following this tutorial.
  8. Member DB83's Avatar
    Jul 2007
    According to the tutorial link you provided, you also require another .dll for Handbrake to rip a protected dvd.
    And reading the comments in the link many have problems.
    Just use a standard ripper and not something that was not designed for the task. You've been a member here long enough to know that.
  9. Originally Posted by DB83 View Post
    What standard ripper do you suggest?
  10. Member DB83's Avatar
    Jul 2007
    This one:
    https://www.videohelp.com/software/DVDFab-Decrypter
    And when you have your files properly decrypted on your hard-drive then you can think about Handbrake.
  11. The link page on this domains states that DVDFab-Decrypter is freeware but it doesn't seem to be. Is it not free to decrypt with that program?
  12. The decrypter part is free.
