Hello
New to the forum
I am currently using filebot to rename all my movies etc. This runs a powershell script. Works very well. One thing I have noticed is that filebot dose not update or even remove / clear the metadata i.e title.
I would like a command line based tool to remove the metadata. FFmpeg was suggested but the command I used appears to need an in file and a outfile.
MP3tag works instantly but requires me to fire up the software,
Any help would be great
Nick
So you've already worked out how to do it with one file and just want to know how to batch the process? To process all mp4 files in a folder:
The will process each file and produce a new file: original.mp4 --> original.cleaned.mp4. You'll have to supply the arguments.Code:for %%F in (*.mp4) do ffmpeg -i "%%F" [other args] "%%~dpnF.cleaned.mp4"
ffmpg MTS to MP4 - no metadata :(
By fabrizio.medici in forum Video ConversionReplies: 5Last Post: 19th Aug 2024, 14:23 -
(HELP PLEASE) FFmpeg - Batch Remove metadata
By uppon2 in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jun 2016, 07:47 -
Looking for a decent MP4 metadata tagger
By unsungno1 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Feb 2015, 04:09 -
Metadata title per track in MP4 container
By Cintax in forum Video ConversionReplies: 7Last Post: 10th Nov 2014, 15:28 -
How to change encoder metadata in mp4
By psycholyzern in forum LinuxReplies: 4Last Post: 11th Jun 2013, 10:46
