Hi everyone. So there's this short film that I've made, which is a no-budget student thing, and unfortunately I didn't record any sound on the set. Now here's the thing: there's a part in the film where we see a silent film with normal audio/perspective, then suddenly we cut to a room where a guy is sitting in front of the TV set and he's watching that film. So obviously this time we need the audio to be heard from a different perspective as if the audio source is coming from the TV. What's the easiest/fastest way to change the audio perspective?
Many thanks in advance
Results 1 to 20 of 20
I also don't know what the OP means .
This intro video seems to suggest it's something in the way it's recorded, or may be adjusted in post in an audio editor.
https://www.lynda.com/Audio-Video-tutorials/Audio-perspective/380257/471924-4.html -
Look up "worldizing".
Alternatively, "impulse response convolution".
Scott -
Thank you all. Unfortunately my English is not good enough. Here's the thing: we're watching a film [full screen/normal] and then suddenly we cut to a room where a guy is sitting in a chair in front of the TV watching that same film that we were watching a second ago. So obviously the audio must be heard from a different perspective because that guy is watching the tv from a distance. I've seen it done with just a click or two in Premiere, but I'm looking for a simple software.
I'd appreciate it if you look at this video:
http://fs2.filegir.com/filemux/1AQ.avi
1. We're watching a film [full screen/normal]
2. Suddenly we cut to a room and that film is still playing on TV so obviously the audio must be heard from a different perspective/aspect/angle/distantce. How can I do that? -
It also helps to add a little room tone. Air conditioner, fan, refrigerator, traffic noise, etc. at a very low level will make it feel like we are in a different place.
Some people spend their careers learning how to edit/mix diegetic sound in a film. You are not going to become a whiz in four days.
Are you working with a stereo file? Left/right doesn't mean anything in mono. -
I gave you an (the?) answer. EXACTLY fits your request. Your choice if you want to take advantage of it or not.
You want it to sound like it is coming out of an old tv set? - MAKE it come out of an old tv set and record it! That's what worldizing is all about.
Impulse response convolution is the digital algorithmic equivalent. Less physical setup, more complex steps & calculations.
(I say this having pro experience in film & tv audio production & post, utilizing techniques such as these).
29.97 to 23.976 - Audio change?
By TheLastOfThem in forum Video ConversionReplies: 22Last Post: 14th Jul 2016, 17:21 -
eac HD audio FPS change
By asiafan in forum AudioReplies: 4Last Post: 29th Oct 2015, 16:28 -
Syncing (audio speed change and more)
By Ranching in forum AudioReplies: 11Last Post: 22nd Sep 2015, 21:44 -
How to change wrapper and audio?
By MKV in forum Blu-ray RippingReplies: 2Last Post: 30th Jul 2015, 14:06 -
Xilisoft Audio Conventer: How to change audio track?
By Hickvell in forum EditingReplies: 4Last Post: 30th Aug 2013, 05:17
I'm looking for a software to handle the perspective of my music/audio.
