Hi,
I am trying to add the usual opaque box to .ass and .ssa files.
I have the same problem on both.
If i try to set the Borderstyle to 3, this is what happens
[Attachment 41626 - Click to enlarge]
As you can see, it looks like two different boxes overlaying on each other (you see the darker part where the two line cross each other).
If I change the Borderstyle to 4 (as often suggested to make the box look as one), here is what happens:
[Attachment 41627 - Click to enlarge]
In this case the box looks good, but the writing suddenly changes showing an ugly shadow.
It's days I'm trying to fix this.
How can I add the usual translucent box we see on many professional subs correctly?
I created the subs on Aegisub (on a Mac).
Thanks to everyone.
If your player doesn't "correctly" handle borderstyle 4 it needs to be fixed in the player or upstream at libass (depending on where the bug is). If you cannot rely on that you have to manually draw boxes.
Subtitle library used by many players to render ASS subtitles.
https://github.com/libass/libass -
Thanks for your help.
Actually I tried one player only, because my main purpose is to create subs that can be burned into the video with the grey translucent box as well, which is not possible with SRT subs.
Using a Mac doesn't help either (can't find a software to burn in ASS and SSA subs). -
I mean report it to the libass developers. When they fix something in libass the fix goes "downstream" to other software that are using libass. Like possibly your player or encoding software like HandBrake.
https://en.wikipedia.org/wiki/Upstream_(software_development)
Problem of AviDemux rendering subtitle with opaque box
By compusic in forum SubtitleReplies: 6Last Post: 15th Jul 2014, 12:27 -
By compusic in forum Newbie / General discussionsReplies: 0Last Post: 15th Jul 2014, 07:54 -
Opaque Box width
By varun_kapoor in forum SubtitleReplies: 0Last Post: 17th Feb 2014, 12:29 -
Remove an opaque logo using Xlogo in Avisynth
By AlanHK in forum User guidesReplies: 34Last Post: 5th Oct 2012, 00:17 -
Opaque image from VHS
By torpidiy in forum Newbie / General discussionsReplies: 27Last Post: 12th Aug 2012, 23:11
