Hi
I have been trying to play some vhsc tapes in an adapter in my vcr but its not playing.
I have made sure there are new batteries in the adapter.
It goes into the machine, then if I hit play it turns the vcr off. It won't rewind or FF either.
I have tried on 2 vcrs.
Any ideas?
Kells
Make sure the VHSC cassette is free to move and isn't jammed.
I'm not that familiar with the cassettes themselves, but if similar to the a full VHS size,
they should have a release button on the bottom so you can manually move the tape.
If that's all OK, take a closer look at the adapter and see if it's mechanically working.
It may also be that your adapter is just for a particular deck. Or you may need to replace it if it's malfunctioning. -
There is an exposed gear on the bottom of the cassette. Turn it by hand to take up any slack in the tape.
VHS tape got stuck in VCR, now VCR plays full static
By Rand251 in forum Newbie / General discussionsReplies: 21Last Post: 4th Apr 2016, 09:40 -
VHS VCR loads tape when won't play/FF/RW
By Darryl In Canada in forum RestorationReplies: 3Last Post: 27th May 2015, 11:33 -
Capturing VHS with VCR or Blu-ray/VCR combo?
By SyncroScales in forum Capturing and VCRReplies: 11Last Post: 26th Dec 2014, 08:39 -
VHS tape won't play, shuts down VCR
By sldvd in forum RestorationReplies: 5Last Post: 7th Mar 2014, 14:26 -
Is there a VCR that will play VHS-C tapes without an adapter?
By moxiecat in forum RestorationReplies: 23Last Post: 25th Oct 2012, 03:24
