Hi,
I already tried to solve this some years ago but finally had to use manual subtitles.
I have videos shot using 300fps and 120fps setting but the resulting video has standard framerate.
MediaInfo output for raw footage is following:
300fps video
andCode:General Format : MPEG-4 Format profile : QuickTime Codec ID : qt 2001.03 (qt /caqv) File size : 855 MiB Duration : 1h 53mn Overall bit rate mode : Variable Overall bit rate : 1 049 Kbps Writing application : Casio Digital Camera Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=30 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1h 53mn Bit rate mode : Variable Bit rate : 1 047 Kbps Maximum bit rate : 22.4 Mbps Width : 512 pixels Height : 384 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.178 Stream size : 854 MiB (100%) Language : English
120fps video:
I am using KDEnlive and the "Dynamic text" feature. Unfortunately, same as Avisynth "ShowFrameNumber" it uses the video framerate and it is not possible to change it.Code:General Format : MPEG-4 Format profile : Sony PSP Codec ID : MSNV (MSNV/mp42/isom) File size : 1.23 GiB Duration : 28mn 49s Overall bit rate mode : Variable Overall bit rate : 6 122 Kbps Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 28mn 49s Source duration : 28mn 49s Bit rate mode : Variable Bit rate : 5 991 Kbps Maximum bit rate : 16.0 Mbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.217 Stream size : 1.21 GiB (98%) Source stream size : 1.21 GiB (98%) Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 28mn 49s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Frame rate : 46.875 fps (1024 spf) Compression mode : Lossy Stream size : 26.4 MiB (2%)
Is there any solution for this? Maybe I could somehow generate SRT/SUB subtitles with timecode as text and then manually change it. But it would need a lot of time...
advice would be helpful
thanks
OK,
I will dive a little bit more in this. Thought AssumeFPS is used to speed up/slow down a video while I only want to keep the current speed (eg. slow-motion) - so keep the current framerate 29.970 fps but show time for the 300 or 120 fps. -
Using this script on a 29.97 fps video:
Code:original_fps = framerate AssumeFPS(120) ShowTime() AssumeFPS(original_fps)
[Attachment 41614 - Click to enlarge]
You can see that the timestamp in the video at frame #60 is 00.5 seconds (what you expect of a 120 fps video), and the frame time indicated by VirtualDub is 2.002 seconds (what you expect from a 29.97 fps video). So the video will play at 29.97 fps, but the printed timestamps will be at 120 fps intervals.
change FPS FROM 120 TO 30 TO REDUCE FILE SIZE
By smokemake in forum MacReplies: 5Last Post: 25th Jan 2017, 09:45 -
Footage FPS is 29.95 and Client wants in 25 FPS
By maxfan in forum Newbie / General discussionsReplies: 5Last Post: 23rd Apr 2016, 23:33 -
In virtualdub can I insert a timecode as well as ffmpeg?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 25th Apr 2014, 03:17 -
Prepare Fast 60 fps Gameplay Footage For Youtube w/ Avisynth
By Kitin in forum Video ConversionReplies: 30Last Post: 22nd Oct 2013, 09:44 -
Program to replace timecode in srt with timecode from another srt
By TehBotolSOsro in forum SubtitleReplies: 19Last Post: 13th Sep 2012, 12:28
