    Apr 2017
    Within the Oort Cloud
    I'm on a windows 7 box using FFmpeg version: 20170223-dcd3418 and would like to control the fade in timing of my logo watermark independent of the fade already built in to my video.
    This code is working OK but I can't work out how to fade the watermark without also fading my input video stream.
     ffmpeg -y -i mainvideo.mp4 -i watermarklogo.png -filter_complex "[0:v]overlay=W-w-10:H-h-10, fade=in:0:20[tmp_overlay]; [tmp_overlay]subtitles=ep1.srt[out]" -map [out] -map 0:a -codec:v libx264 -crf 18 -preset slow -pix_fmt yuv420p -c:a aac -strict -2 output.mp4
    I've tried a number of combinations but am out of my depth with FFMPEG's -filter_complex command so any help would be appreciated.
    Please let me know if I can provide further information.
  2. Originally Posted by EasyFeet View Post
    Use alpha channel.
  3. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    If you can use AVISYNTH with ffmpeg you can control all aspects of fadein and fadeout by number of frames and the script is easier than the overlay used by ffmpeg alone. The following avisynth script allows srt (ssa also will work) subtitles as well as an overlay of a second video.
    LoadPlugin("C:\Users\Bud\Desktop\VSFilter.dll")
    v1 = Directshowsource("C:\Users\Bud\Desktop\[dp]Manjandani-1.mp4").ConvertToRGB32.Lanczosresize(864, 368)
    v1=v1.textSub("C:\Users\Bud\Desktop\Wham.srt")
    img1 = DirectShowSource("C:\Users\Bud\Desktop\Wham!Last Christmas.mp4", pixel_type="RGB32", fps=23.976).converttoRGB32.LanczosResize(160,90)
    img2 = DirectShowSource("C:\Users\Bud\Desktop\Wham!Last Christmas.mp4", pixel_type="RGB32", fps=23.976).converttoRGB32.LanczosResize(160,90)
    img3 = DirectShowSource("C:\Users\Bud\Desktop\Wham!Last Christmas.mp4", pixel_type="RGB32", fps=23.976).converttoRGB32.LanczosResize(160,90)
    img4 = DirectShowSource("C:\Users\Bud\Desktop\Wham!Last Christmas.mp4", pixel_type="RGB32", fps=23.976).converttoRGB32.LanczosResize(160,90)
    clip1 = v1.trim(0, -101).Overlay(img1.assumefps(23.976).trim(0,-101).fadein(60).fadeout(60), 100, 100,Opacity=1.0, img1.ShowAlpha()) \
     ++ v1.trim(101, -99) \
     ++ v1.trim(200, -101).Overlay(img2.assumefps(23.976).trim(200,-101).fadein(60).fadeout(60), 150, 150,Opacity=1.0, img2.ShowAlpha()) \
     ++ v1.trim(301, -99) \
     ++ v1.trim(400, -101).Overlay(img3.assumefps(23.976).trim(400,-101).fadein(60).fadeout(60), 200, 200,Opacity=1.0, img3.ShowAlpha()) \
     ++ v1.trim(501, -99) \
     ++ v1.trim(600, -101).Overlay(img4.assumefps(23.976).trim(600,-101).fadein(60).fadeout(60), 250, 250,Opacity=1.0, img4.ShowAlpha()) \
     ++ v1.trim(701, 0)
    return clip1
    The above is a little overkill but shows 4 logos (img) fading in and out from black in different locations. The opacity can be set from 1.0 (Opaque) to 0.0 (Transparent). The fps of the img is set to the fps of the main video. The dot "." filters (assumefps, fadein, fadeout, etc.) follow each item that you wish to control. The below image may help to clarify the script:
