I have created 41 VOB files from a DVD and would like to make anther DVD out of them. However, they are too big together to fit in one DVD even though they came from one. I need to reduce each one of them. I have searched many web pages about it but I have not found any good ones yet. I am hoping that I can do so for free of charge.
DVDs are not created WITH VOB files, they are created with DVD compliant MPEG2 files.
Whoever told you that the VOB files taken from a DVD are "better" than the MPEG2 files that created them is wrong.
The reason that they do not fit is that you took these VOB files from a dual-layer DVD and you are trying to put them back to a single-layer DVD.
Stop messing with VOB files. -
Or use a DL DVD.
No reason to waste a lot to time messing with the files and reducing the quality.Google is your Friend
VOB files
By kalemvar1 in forum DVD RippingReplies: 2Last Post: 22nd Nov 2016, 17:13 -
Convert video files to x265 in order to reduce file size?
By kingmustard123 in forum EditingReplies: 3Last Post: 2nd Oct 2016, 00:59 -
AVI files sizes too big, need to reduce
By kinseykick in forum Newbie / General discussionsReplies: 11Last Post: 30th Apr 2014, 15:28 -
Reduce Blu Ray FOLDER/FILES to record a 25 GB Blu Ray
By xeikon in forum Video ConversionReplies: 4Last Post: 18th Mar 2014, 15:20 -
Is it possible to convert VOB files to AVI files?
By Sulli in forum Newbie / General discussionsReplies: 14Last Post: 14th Oct 2012, 01:01
