    Dec 2002
    Im trying to simply insert a clip in front of the original audio clip, Can any Audacity Guru tell me how, or even add the new clip in a new line and then add a time delay to the original....Cheers
  2. Generate>Silence?
    Dec 2002
    Is there a method of inserting a clip in front of the original.....??
  4. Mod Neophyte redwudz's Avatar
    USA
    In Audacity, click 'Help' and 'Quick help', choose 'FAQ' in the left column, near the bottom.
    Then 'Editing'>'How do I combine two files into one longer file'.
    You should see the instructions you need.
  5. Open both clips. Select the one you want to insert. Copy to the clipboard. Put the cursor at the start of the copy you want to insert into. Paste.
