Im putting together a project of a Cold War Warning System which will play warning sounds in MP3 format, sampled from a Documentary made on the subject, however the main sample I need, has the sound of something being smashed included in the clip. Is there anyway of somehow removing this unwanted sound......If this is not possible Im intending to record my own vocal track, but it requires altering as though it was being broadcast down an old telephone line in a similar manner to the sample, is there a program that has such a filter to allow me to do this.....
ATTACK RED 1.mp3
Don't think the noise can be removed. There's no frequency separation, as both signals are highly distorted.
Yes, that can be done in Audacity.
1. High pass, 150Hz
2. Low pass, 3000 Hz
3. Distortion -- for example, try these:http://www.instructables.com/id/DistortionOverdrive-Effect-in-Audacity/
(this one is really too strong for your purposes)
1. Effect, Audacity, Leveller.* Degree of Leveling = Heaviest
2. Effect, Repeat Leveller
* Threshold Noise = -35 dB
3. Effect, Audacity, Leveller.* Degree of Leveling = Heaviest
* Threshold Noise = -50 dB
MORE DISTORTION EFFECTSEffect, LADSPA, Diode Processor
* Mode = 1.0 (half wave)
Effect, LADSPA, ViNil (Vinyl Effect)
* Year = 1931
Effect, LADSPA, Valve Saturation
* Level = 1.0
* Character = 0.0 -
Crash sound removal: ain't happenin'. Distortion can be achieved by blowing out the peaks with the Amplify filter (allow clipping, work in integers, not floating point), then lowpass, highpass filtering.
Thanks for the educated advice chaps, I have used a TEXT to SPEECH clip, and am going to apply Raffriff's advice. Thanks again!!
This software would probably do it - great for forensic work and a whole lot more however the price is really not for a one off situation, maybe you might approach a professional studio that's will to assist? https://www.izotope.com/en/products/repair-and-edit/rx/rx-advanced.html
Removing background music in a video
By muffinman123 in forum AudioReplies: 12Last Post: 17th Sep 2015, 13:44 -
Help needed - Removing unwanted audio languages from DVD? (VOB, IFO)
By SE14man in forum Newbie / General discussionsReplies: 10Last Post: 24th Aug 2015, 07:54 -
Removing Unwanted Audio Portions From a Video Clip
By D.V. Dee in forum AudioReplies: 3Last Post: 6th Apr 2014, 10:17 -
TMPGEnc-menus background going to green screen or previous menu background
By DwightFry78 in forum Authoring (DVD)Replies: 0Last Post: 31st Jul 2013, 14:11 -
Removing unwanted scene from a MP4 Video
By w11x22 in forum EditingReplies: 2Last Post: 14th Sep 2012, 13:07
