  1. Trying to have mediainfo create an nfo for each individual mkv in a folder, outputting them into individual nfo files, retaining the original filename ideally.
    I've figured out how to make it output all the mkv info in a folder into one file, is there any way to have it split the nfo automatically between however many files it reads?
  2. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    What are you using to create the nfo file. What is the code for writing tbe file?
  3. Put this in a batch file in the folder of MKV files, name it MInfo.bat or whatever:
    For %%F IN (*.mkv) do ("C:\Program Files\MediaInfoCLI\MediaInfo.exe" "%%F" >"%%~dpnF.NFO")
    Change the path to MediaInfo CLI, then double click on it.
  4. Originally Posted by jagabo View Post
    This is exactly what I was looking for, thanks!
