Results 1 to 12 of 12
    May 2017
    los angeles
    Hey guys im fairly new here, I just have a quick question I been trying to figure this out. I Have some mkv with dts audio that would like to convert to mp4 with ac3 audio but keeping same quality on the video,I know the sound is going to suffer but im ok with that is there a tool that i could use that would do that for me. If so can you guys point at me with the proper program or guide.
    thanks in advance.
  2. ffmpeg -i "input.mkv" -c:v copy -c:a ac3 "output.mp4"
    There are also a lot of ffmpeg based GUIs in case you don't feel comfortable with the console. For example Xmedia Recode (set output format to mp4, set video codec to copy and audio codec to ac3.)
    Aug 2013
    Central Germany
    Also specific "re-multiplexers" which mostly avoid re-encoding, like BOX4.
  4. Member stax76's Avatar
    Nov 2009
    On thin ice
    In staxrip you would select 'Just Mux' to direct stream copy.
    May 2017
    los angeles
    hey guys im really confuse i did tried xmedia encode but when i did the audio and put ac3 it made a 1gb file. and also box4 is preety good it gave me really good size mp4 but how can i make box4 give me the exact video quality on the mp4 and how would xmedia do me the exact video with the ac3 since on the option of video codec doesnt give me the option to copy
  6. BOX4 never changes video but it cannot convert audio to AC3, only AAC and MP3.
    For Xmedia recode copy instead of convert:
    May 2017
    los angeles
    Hey guys well I did what you told me @sneaker i did put my mkv i went to video on mode i put copy on audio ac3 and it starts converting it and when its half way it completes it and it gives me my mp4 but when i check on mediainfo the bitrates are way off from original mkv and mp4
  8. Post MediaInfo text log (View->Text) of input and output file.
    May 2017
    los angeles
Name:	mp4 completed.jpg
ID:	41592Click image for larger version
ID:	41593 here you go
    May 2017
    los angeles
    i dont have a super computer but all encodes are being super fast like i gota 8gb file that did it in a min
  11. Click the "output" first. (I don't know why the GUI is this strange. It is confusing.)
  12. Originally Posted by nr140e View Post
    Hmm... Maybe that wasn't the problem, then. I don't know, sorry. Maybe it's a bug.
