Hi!
I have capture card up to 1920x1080.
I want to capture from device with resolution 1920x1200, what outputs error at viewing by capture device.
For this reason (source is VGA) I'm using cheap VGA to Composite and S-Video Converter and then to device which scales it up to 1440x900.
You now know that worst quality loss is in conversion to CVBS or SVHS, even then signal is scaled up...
Exists any direct downscaler of 1920x1200 WUXGA video to 1680x1050 WSXGA+ video?
I mean simple downscaling device, nothing more, nothing less, best with VGA input.
Various up/downscalers existing and supports more that I need and offers much more what I want - and it is visible in price.
I want to buy not precious device which is downscaler only and has this downscaling mode.
Can anybody help me?
Thank you very much.
Miro
Unless you can find something used on ebay, there is probably nothing that can do what you want at the price you want to pay.
I found nothing new for less than $200. (That is $200 for an item sold in the USA, not in the price that would be charged in Europe.) This is the item: https://www.startech.com/AV/Converters/Scalers/vga-hdmi-converter~VGA2HDPRO2Last edited by usually_quiet; 13th May 2017 at 17:39. Reason: typo
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
More info on the source might provide better answers, i.e. if this is your Commodore 128, why scale it up so much in the first place?
http://www.amibay.com/showthread.php?86858-C128-CGA-to-RGB-adapter&
^ "Tested with a cheap SCART to HDMI adapter from eBay, works fine."
If it's actually 1920x1200 VGA from a modern PC, possibly the Open Source Scan Converter? No idea what its upper limits are. -
No, this I need for other retro computer. Or better to say reborn retro computer.
Enhanced Commodore 65 - new computer with name Mega 65.
It has native resolution 1920x1200, of course it uses scaling for generating screen 640x200, or better to say - default display it 640x200 in frame 1920x1200, but is possible to use up to 1920x1200 resolution - no matter of resolution used, it always produces hardware output 1920x1200...
Miro -
It doesn't appear that the OSSC will work for 1920x1200 60Hz input. The specs for the OSSC from videogameperfection.com say the following:
Supported input resolutions
240p/288p/480i/576i 15khz
25Khz medium-res modes
480p/576p/720p 31khzIgnore list: hello_hello, tried, TechLord, Snoopy329
Folder already exists when it does not
By jyeh74 in forum ComputerReplies: 1Last Post: 23rd May 2016, 04:56 -
Getting direct video link from this website
By alexfb in forum Video Streaming DownloadingReplies: 1Last Post: 13th Dec 2015, 01:50 -
Auto-rename by ffmpeg if output file exists?
By pxstein in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2013, 04:42 -
Extracting MMS Video Stream - Cannot find direct video link
By childofsai in forum Video Streaming DownloadingReplies: 6Last Post: 21st Feb 2013, 18:18 -
Playing video direct from usb stick to tv
By rronald_25 in forum DVB / IPTVReplies: 6Last Post: 28th Jun 2012, 02:04
