MOst devices that have 384khz seem to be devices that are using digital (not analog) audio, and ones that support both analog and digital, only the digital has the 384khz sampling. The analog inputs and outputs are still only using 192khz sample rates.
Does anybody here know of any 384khz device that has 384khz for its analog input, or analog output (and preferably both)?
The M-Audio Transit Pro claims to have 384 kHz sampling. If M-Audio is doing it, there must be others.
I'm sorry but talking about 384K or 192K sample rates for analog inputs or outputs make zero sense to me. Sampling rates are in the digital domain.
Anyway, I downsample 24 bit audio anyway, to 16 bit 44.1K or 48K, depending on the input sample rate, si it divides evenly. It sounds identical and saves a lot of HD space. The sole benefit to HD recordings is better mastering, which isn't anything to sneeze at. And the result just wipes the floor with the CD version of same. -
Some audiophile DAC's support very high sample rates, for high speed acquisition you may try to search for measurement ADC with USB connectivity - something like this https://www.mccdaq.com/usb-data-acquisition/USB-2600-Series.aspx
MKVToolNix merging with different audio sample rate
By ge0rg in forum Video ConversionReplies: 9Last Post: 9th Sep 2016, 18:31 -
Bit rate question
By SameSelf in forum Video Streaming DownloadingReplies: 3Last Post: 21st Sep 2015, 14:00 -
Portable Capture Devices Question
By Revan654 in forum Capturing and VCRReplies: 45Last Post: 17th Sep 2014, 12:49 -
Lower audio sample rate in an mkv?
By Arttworx in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jan 2013, 11:50 -
Confused about sample rate?
By JamesWade in forum AudioReplies: 8Last Post: 23rd Oct 2012, 04:59
