hey bros!
Sorry if this is answered before.
My cable TV box has encryption enabled.
If i use this
https://www.amazon.com/ViewHD-Powered-Splitter-1080P-Model/dp/B00J4D3RTU?th=1
and then connect with some Samsung LED which can record. Will those recordings work on other devices?
I don't know what you mean by "Samsung LED which can record". Anyway make sure to ask the seller to confirm the HDCP bypass before you buy the splitter, Also you need an HDMI capture box or an android box that has the capability of recording from an HDMI input. Some android boxes are capable of ignoring HDCP and have HDMI out for your TV.
The ViewHD Ultra HD VHD-Pluto won't allow you to record from a cable box's HDMI connection. The ViewHD VHD-1X2MN3D will.
Hauppauge 1512 (HD-PVR 2) Questions for capturing HDTV
By kkiller23 in forum Capturing and VCRReplies: 12Last Post: 10th Sep 2014, 15:54 -
LED TV advice
By siluet in forum DVB / IPTVReplies: 15Last Post: 3rd Jul 2014, 03:35 -
Convert non-linear stretched 16x9 HDTV video back to 4x3 HDTV?
By bigfan5 in forum DVB / IPTVReplies: 13Last Post: 5th Jun 2013, 14:22 -
Help with LED TV
By Luna72 in forum DVB / IPTVReplies: 21Last Post: 12th Apr 2013, 02:25 -
Capturing HDTV to MAC via (HDMI to USB)
By legionar2010 in forum MacReplies: 4Last Post: 10th Feb 2013, 08:48
