I got sometimes video files in MP4 format which contain ads (at the beginning, at the end and in the mid).
Now I search a simple, portable video editor which let me delete such ad chunks WITHOUT re-encoding the full video.
For a precise positioning onto the start and end frame for the interval to cut/delete the video editor needs
a comfortable frame-wise forward/backward stepping.
After having deleted some chunks I just want to select "Save" to save the remaining stuff into a new *.mp4 file.
I need no other, advanced features like fade in/out or resolution change or colorization or whatever....
Since I want to run that tool from USB flash drive the video editing sofwtare should be portable.
In the past there was the famous "VirtualDub" editor for that purpose.
Unfortunately this tool does not work for MP4 files.
Maybe someone can recommend me an alternative video editor for that task
Thank you
If I'd known I was going to live this long, I'd have taken better care of myself.
I could care less if he is looking for free. I simply wanted to tell him what I thought was the best tool for the job. VideoRedo isn't that much money. People need to quit thinking that all software should be free. Yes, there is some great free software; there is great shareware; and there is great software for which you pay money. The commercial software tends to have a lot more depth (fuller-featured) and, with the good stuff, a far better UI.
MP4 Video and Audio Tag Editor [for PC]
By duesouth in forum AudioReplies: 0Last Post: 19th Oct 2016, 10:18 -
Splitting h264 (no re-enc.), difference mkv and mp4?
By Spiny Norman in forum Video ConversionReplies: 5Last Post: 23rd Dec 2015, 15:48 -
Cut up mp4 file into chunks without reencoding/loss of quality?
By Xirix in forum EditingReplies: 1Last Post: 5th May 2015, 14:43 -
How to capture video chunks frames of data in realtime from HVR 2250?
By rshapiro in forum Capturing and VCRReplies: 19Last Post: 27th Aug 2014, 06:41 -
Removing Chunks of a Video Where Nothing Happen (Video and Sound)
By Mordan in forum Video ConversionReplies: 28Last Post: 16th Mar 2013, 09:48
