Just yesterday, my Windows 7 machine started acting odd. When I hit a key to bring it out of sleep mode, it sounds like it's waking up, but the screen doesn't come on. So I turn it off. Then wait a minute and turn it back on. When it boots, it runs chkdsk, which I figure is normal since I didn't properly shut it down. Everything seems fine. Go into windows, go about my work. Put it to sleep and the same thing happens next time. So I turn it off instead of putting it to sleep thinking something is wrong with the sleep feature. Next time I turn it on, there's that chkdsk screen again. Also I notice that when I start Chrome, all my extensions are gone, and two new ones are installed "search manager" and "utab" so I remove them immediately. Starting to research this, I looked up about chkdsk running at each boot and found this article:
http://www.hightechdad.com/2013/04/25/how-to-stop-chkdsk-from-running-on-every-boot-up/
When I ran the command, the response is "Volume - c: is Dirty"
So the article doesn't say what to do if it's Dirty, only what to do if it's not..
I ran malware bytes and came up with this (see attached). Removed everything it found, and going to reboot to see what happens. Is this "dirty" a common thing? What should be done?
Microsoft has a reply for that issue here:
https://answers.microsoft.com/en-us/windows/forum/windows_xp-update/upon-start-up-wind...f-aa5c9e8ca221
Although the link refers to XP, I believe that it applies to your Win 7 also.Extraordinary claims require extraordinary evidence -Carl Sagan
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
[Help] Problems with the "Title Button" in the "VTS ROOT" and "VTS Normal"
By kirous in forum Authoring (DVD)Replies: 8Last Post: 1st Nov 2014, 13:31 -
How to convert "Still Image" to "AVC file" (like as Godzilla Blu ray Menu)
By ningnong132 in forum Video ConversionReplies: 2Last Post: 8th Sep 2014, 05:23 -
the "-intra" command in ffmpeg.exe affects encoding "-vcodec copy" mode?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2013, 16:53 -
Sony RDR-GX7 "disk is dirty"
By blsachs in forum DVD RippingReplies: 8Last Post: 29th Apr 2013, 23:12
