https://forum.handbrake.fr/viewtopic.php?f=33&t=36364SECURITY WARNING
Anyone who has downloaded HandBrake on Mac between [02/May/2017 14:30 UTC] and [06/May/2017 11:00 UTC] needs to verify the SHA1 / 256 sum of the file before running it.
Anyone who has installed HandBrake for Mac needs to verify their system is not infected with a Trojan. You have 50/50 chance if you've downloaded HandBrake during this period.
Detection
If you see a process called "Activity_agent" in the OSX Activity Monitor application. You are infected.
For reference, if you've installed a HandBrake.dmg with the following checksums, you will also be infected:
SHA1: 0935a43ca90c6c419a49e4f8f1d75e68cd70b274
SHA256: 013623e5e50449bbdf6943549d8224a122aa6c42bd3300a1bd 2b743b01ae6793
The Trojan in question is a new variant of OSX.PROTON
Removal
Open up the "Terminal" application and run the following commands:Then Remove any "HandBrake.app" installs you may have.
- launchctl unload ~/Library/LaunchAgents/fr.handbrake.activity_agent.plist
- rm -rf ~/Library/RenderFiles/activity_agent.app
- if ~/Library/VideoFrameworks/ contains proton.zip, remove the folder
Further Actions Required
Based on the information we have, you must also change all the passwords that may reside in your OSX KeyChain or any browser password stores.
Apple
We have been informed that the process to update the definitions for OSX's XProtect feature started this morning, so this should start rolling out to machines automatically soon if not already.
Summary
- HandBrake-1.0.7.dmg was replaced by another unknown malicious file that DOES NOT match the SHA1 / SHA256 hashes on our website or on our Github Wiki which mirrors these: https://github.com/HandBrake/HandBrake/wiki/Checksums
- The Affected Download mirror (download.handbrake.fr) has been shutdown for investigation.
- The Primary Download Mirror and website were unaffected.
- Downloads via the applications built-in updater with 1.0 and later are unaffected. These are verified by a DSA Signature and will not install if they don't pass.
- Downloads via the applications built-in updater with 0.10.5 and earlier did not have verification so you should check your system with these older releases
When relevant information becomes available we will update this post.
Notices
- The Download Mirror Server is going to be completely rebuilt from scratch so downloads may be a bit slower than usual while the primary picks up the load. During this time, old versions of HandBrake will not be available.
Results 1 to 1 of 1
Handbrake problem (Mac) - will not display part of a logo (but it did once)
By boots27 in forum SubtitleReplies: 4Last Post: 14th Nov 2015, 04:32 -
Mac and Handbrake CLI - ISO to MKV
By TaT-DK in forum MacReplies: 2Last Post: 13th Jun 2014, 04:40 -
Best DVD backup settings with HandBrake for Mac?
By elboghdadly in forum Video ConversionReplies: 8Last Post: 10th Mar 2014, 06:21 -
PrcViewer malware warning after installing multiAVCHD from videohelp mirror
By rjamesd05 in forum Authoring (Blu-ray)Replies: 13Last Post: 19th Dec 2013, 10:14 -
Handbrake settings for Quicktime (Mac)
By flips01 in forum MacReplies: 7Last Post: 5th Aug 2012, 15:08
