As the recent news of the alleged cracking of AACS 2.0 is a bit of sensitive subject here, getting forum members in trouble. So I'll preface my post with the forum rules first.
Talking about decrypting, backing up, or converting your media you own for fair use (backup) is allowed here. Going so far as to host decrypting software like DVD Decrypter and MakeMKV on Videohelp.com. As well as talking about dealing with Macrovision on VHS is allowed.Warez rules
What is warez? Obtained movies/tv-series/tv-shows/software either through download, torrent, etc that breaks the copyright.
Do NOT talk about warez releases
Like filenames Movie.2012.DVDSCR.X264.AAC.P2P.mkv. Please don't download warez movie/tv releases.
Do NOT talk about copying rented/subscription material
You are not allowed to rip/copy/record rented video. It includes streaming rented/subscribed video like netflix, itunes, hulu plus, etc.
Do NOT give warez / Do NOT link to warez
Distributing warez. This includes linking to warez either directly or to crack or serial sites. Offering warez in any fashion including PM or e-mail is against forum policy.
Do NOT ask for warez
Asking for warez. In any fashion this is unacceptable including but not limited to PM or e-mail requests or information on what p-2-p network has copies.
Do NOT provide information on how to obtain warez
Providing information on how to obtain warez.
Do NOT advocate warez
Advocate warez. Recommending the use of warez.
With that out of the way, I figured would share the Mediainfo of the UHD Bluray from the recently alleged AACS 2.0 crack. This mediainfo was not created by me but I copied it from a source which shall go unnamed. I also redacted a few things below but left everything else unchanged. It is alleged to of come off a UHD-66 Dual-Layer Disc, and the box art labeled it as a HDR video.
This UHD Bluray video may have been a one off fluke, which was obtained without cracking AACS 2.0. But it's still of interest to get a better idea of what kind of videos UHD players play.Code:General ID : 0 (0x0) Complete name : C:\.........\BDMV\STREAM\00001.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 53.1 GiB Duration : 1 h 44 min Overall bit rate mode : Variable Overall bit rate : 72.5 Mb/s Maximum Overall bit rate : 109 Mb/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High Codec ID : 36 Duration : 1 h 44 min Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : SMPTE ST 2084 Matrix coefficients : BT.2020 non-constant Mastering display color primaries : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000 Mastering display luminance : min: 0.0050 cd/m2, max: 4000.0000 cd/m2 Maximum Content Light Level : 1132 cd/m2 Maximum Frame-Average Light Level : 923 cd/m2 Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : Atmos / TrueHD / AC-3 Mode extension : CM (complete main) Format settings, Endianness : Big Muxing mode : Stream extension Codec ID : 131 Duration : 1 h 44 min Bit rate mode : Variable / Constant Bit rate : 640 kb/s Maximum bit rate : 8 124 kb/s Channel(s) : Object Based / 8 channels / 6 channels Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Sampling rate : / 48.0 kHz / 48.0 kHz Frame rate : 31.250 FPS (1536 spf) Bit depth : 16 bits Stream size : 480 MiB (1%) Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 1 h 44 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 spf) Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -8 ms Stream size : 480 MiB (1%) Audio #3 ID : 4354 (0x1102) Menu ID : 1 (0x1) Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Mode : 16 Format settings, Endianness : Big Muxing mode : Stream extension Codec ID : 134 Duration : 1 h 44 min Bit rate mode : Variable / Constant Bit rate : Unknown / 1 509 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 spf) Bit depth : 16 bits Compression mode : Lossless / Lossy Audio #4 ID : 4355 (0x1103) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 1 h 44 min Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 spf) Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -8 ms Stream size : 144 MiB (0%) Audio #5 ID : 4356 (0x1104) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 1 h 44 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 spf) Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -8 ms Stream size : 480 MiB (1%) Text #1 ID : 4768 (0x12A0) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Text #2 ID : 4769 (0x12A1) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Text #3 ID : 4770 (0x12A2) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Text #4 ID : 4771 (0x12A3) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Text #5 ID : 4772 (0x12A4) Menu ID : 1 (0x1) Format : PGS Codec ID : 144
That wasn't exactly a secret to begin with.
http://www.blu-raydisc.com/assets/Downloadablefile/BD-ROM_Part3_V3.0_WhitePaper_150724.pdf -
Currently there have been 6 official UHD Discs known to of been decoded but still don't know how it's being done.
DVDFab Announces no AACS 2.0 decryption to crack the next-gen 4K UHD Blu-ra
By DVDFab Staff in forum Newbie / General discussionsReplies: 27Last Post: 18th Apr 2016, 10:17 -
Video discussing UHD, HFR, HDR and WCG etc.
By hello_hello in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2015, 20:11 -
How to apply encryption (AACS, BD+, etc.) to a Bluray/AVCHD ?
By ahmadka in forum Authoring (Blu-ray)Replies: 7Last Post: 21st Oct 2013, 19:11 -
Nothing I Have Opens This Video (MediaInfo incl.)
By hech54 in forum EditingReplies: 7Last Post: 6th Sep 2013, 15:55 -
Why MediaInfo says 25fps while my video is actually 50i ?
By Sam0403 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 8th Jul 2012, 07:48
