I want to stream something that is made of lots of m2ts files and then join them . How would i do this? I seem to recall doing this or similar but cannot recall how
Hi Sounds ,
Below an example :
!!! BE SURE THAT ALL .M2TS FILES HAVE THE SAME STRUCTURE !!!
1) Create a directory E:\concat
2) insert the file "FFMPEG.EXE" , in that folder
3) Copy in that folder , all files .m2ts
4) Create a file "mylist.txt" in that folder . See example below :
5) Create a batch file . See example below :Code:file 'E:\concat\media_1.m2ts' file 'E:\concat\media_2.m2ts' file 'E:\concat\media_3.m2ts'
Launch the batch file to get the file "3_fichiers.mkv" .Code:@echo on "ffmpeg.exe" -f concat -i mylist.txt -c copy "3_fichiers.mkv" pause :fin
Cheers .JE SUIS CHARLIE !!!
[SOLVED] How to join MP4 files where some have more than one audio stream?
By yetanotherlogin in forum EditingReplies: 3Last Post: 19th Nov 2015, 05:32 -
Clown BD to join multiple m2ts files?
By justinrye in forum Newbie / General discussionsReplies: 6Last Post: 8th Nov 2014, 16:08 -
Replacing multiple M2TS files with one large M2TS - possible??
By kpic in forum Authoring (Blu-ray)Replies: 0Last Post: 1st Nov 2014, 01:55 -
Help with multiple .m2ts files to one .m2ts
By neworldman in forum Blu-ray RippingReplies: 10Last Post: 4th Sep 2013, 11:16 -
How to set default audio stream when playing m2ts file?
By Unufri in forum Video ConversionReplies: 1Last Post: 20th Feb 2013, 03:46
