  1. Hi. I've got a Sanyo 1500A DVD Player... The thing is.. Whenever I create a VCD on my computer and put it to play it goes very well until there's 20 minutes left for the end of the VCD... Then it starts to pop the image, and it starts to scrubble and disappear and lock and making all these strange sounds... Can anyone help me out here???
    THANK YOU
    -> also.. i'd like to know if there's any code for Macrovision disabling on this dvd player of mine...
  2. Yeah man I get the same thing but mine starts to stuff up as soon as u start to play and does so every 10 sec intervuls, did u fix da problem??
    Regards Matt
    Apr 2002
    Ireland
    what speed are you burning your vcd's at? when i first made vcd's i found some of them stuttered during the last 10 minutes as well. i started to burn them at lower speeds(4x) and i have'nt had a problem since. it seems some dvd players have problems with dvd's burnt at high speeds.
  4. 8) Also, I don't know if you over burn, but that tends to happen also when you overburn a little too much towards the end of the disk.
