please help in th easiest, fastest and best way to convert MKV to MP4, and another question please when i download videos from youtube can i change the extension of the videos cz it gives me always mkv with 1080 hd![]()
Renaming does not work. But you can directly download mp4 from youtube.
For example (720p max):
youtube-dl -f mp4 https://www.youtube.com/watch?v=tO01J-M3g0U
For best quality mp4 (higher than 720p):
youtube-dl -f "bestvideo[ext=mp4]+bestaudio[ext=m4a]" https://www.youtube.com/watch?v=tO01J-M3g0U
https://forum.videohelp.com/threads/382524-How-to-get-started-with-youtube-dl-from-the...command-prompt -
And it converts (reencodes), wasting time and degrading the video.
As Keyser suggested, MKVToMP4.
No it doesn't. YouTube doesn't even use MKV so whatever you're using to get the video is changing it to MKV, either by changing containers (no reencode) or by reencoding. As sneaker suggests, just download the MP4 instead. There are plenty of programs to do that without having to mess with command lines.cz it gives me always mkv with 1080 hd -
Browser extensions are the most easy and obvious way to download from youtube I guess. youtube-dl is handy if you want to do something no other app can do like download a complete music channel and remember which tracks were already downloaded in a previous session, youtube-dl remembers it with --download-archive.As sneaker suggests, just download the MP4 instead. There are plenty of programs to do that without having to mess with command lines.
best n fastest converter to convert .mkv or other video files for LG plasma
By lalson639 in forum Video ConversionReplies: 5Last Post: 28th Feb 2013, 09:40 -
Easiest way to convert 25fps mkv to 23.976
By leandronb in forum Video ConversionReplies: 9Last Post: 5th Feb 2013, 07:30 -
Cannot seem to convert MKV to MP4 or AVI to MP4 without audio sync issues
By Matth3w in forum Video ConversionReplies: 0Last Post: 16th Sep 2012, 14:36 -
convert mkv to smallest and fastest
By chowa in forum Video ConversionReplies: 3Last Post: 21st Aug 2012, 12:28 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19
