Quick dumb question.
Does this ONLY capture in DV format?
Or would this device be recognized by VirtualDub as a Capture Source?
I've not been able to get a DV codec working in Windows 7 Professional. But could easily encode to Huffy or whatever else, if this device is supported by Vdub.
GAH! I picked the wrong forum, I'm so sorry.
It doesn't 'capture' at all, just transfers the DV video file to your computer. You can't change that.
Try using WinDV for the transfer. -
As far as I know, it only does DV output over Firewire.
Which DV codec(s) have you tried to get working under Win7? Try downloading and installing the trial version of Corel's VideoStudio Pro; it supports DV-over-Firewire from the ADVC100. (Or at least it does on my machine.) -
Actually, you CAN use virtualdub to capture with an ADVC. Well it just worked with my 300
Yes, but of course it's just taking in the DV stream from the ADVC via DirectShow.
Canopus ADVC-100 vs. ADVC-110 vs. ADVC-300
By TrackingError in forum Capturing and VCRReplies: 36Last Post: 16th Jul 2021, 12:19 -
SVHS, Canopus ADVC-100 to 1394 Firewire...Best Captrue Settings?
By lan2234 in forum Capturing and VCRReplies: 2Last Post: 24th Jun 2016, 10:38 -
Canopus ADVC-100 to VHS, SVHS via Firewire 1394?
By lan2234 in forum Video ConversionReplies: 3Last Post: 1st Jun 2016, 15:43 -
Canopus ADVC-100 Problem
By Johncaig in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jul 2014, 16:14 -
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26
