The video plays and can be exported from QuickTime in Mac OS X Snow Leopard 10.6.8 with Flip4Mac installed.
Results 31 to 40 of 40
Here is the video, converted and uploaded to a file host: https://workupload.com/file/3EDTY6k
If you have more of these type of videos, your system will work with Flip4Mac which will allow viewing and exporting that video. https://www.telestream.net/flip4mac/overview.htm -
You could just download a much better version from Youtube: https://www.youtube.com/watch?v=NYwodjYZdrI
Hello there! I have the same problem, except my files are from our Wedding Reception. I’ve tried everything above and while I can get the video to play, the audio doesn’t. I know there is audio in there in Windows Media Audio 9 Standard format, and similar to the OP these files did play when I received them. I’ve managed to export the audio to AIFF but it comes out garbled every few seconds, so it seems it doesn’t have the exact codec it needs. Would someone be willing to take a look?
I don't have anything that plays the video or audio correctly. The only audio I could get was just a series of clicks and chrips. Using MKVToolNix or ffmpeg to remux to other containers didn't help.
Thanks for trying, jagabo. I’ve sent BananaFiasco a PM to see if he can make the conversion on the setup he listed above. It’s definitely a tough nut to crack because even between Flip4Mac versions results will vary (and later versions will actually not play the audio at all).
Huffyuv Codec Problem?
By MrJacobAngle in forum Software PlayingReplies: 13Last Post: 20th Aug 2020, 17:01 -
Problem with MOV file codec (qt 2005.03 (qt))
By John Stakes in forum Software PlayingReplies: 5Last Post: 26th Apr 2017, 14:21 -
YV12 codec problem?
By chazz spacey in forum Video ConversionReplies: 24Last Post: 9th Dec 2014, 13:58 -
All in one codec Needed
By RBCC in forum Video Streaming DownloadingReplies: 4Last Post: 21st Jun 2014, 09:41 -
Quicktime codec problem?????
By Riversound in forum Software PlayingReplies: 8Last Post: 5th Jul 2012, 18:22
