GCC 7.1.0 has been officially released. This is a Windows build, to be used with an MSYS2 environment.
It should be compatible with the inclusion of ffms in the 64-bit builds of x264.exe.
So far, I tested it only with the latest x265 source-code, and "everything went fine".
But YMMV, of course. https://gcc.gnu.org/gcc-7/porting_to.html
Normally I share my GCC .7z archives at Mediafire, but because Mediafire is refusing new uploads,
I decided to share this one through Videohelp. Download, unrar, profit.
AnonymousGuest
AnonymousGuest
oh my god. you just saved me a lot of pain. i have a problem that is apparently only solvable with style via c++17's variant, which is only available on g++-7, which is only available on experimental linux repos, but nowhere on windows if you do not want to compile it yourself. which i tried and failed with some error i have not found a solution for.
this is a rather interesting place to upload such things
but, god bless you or something for doing it anyway. my code works now (or at least the mentioned problem is solved).
BIG THANKS <3
