Computers are bastards.
About 3 years ago I bought a USB3 card for my old PC. It was an NEC controller when I bought it (I'm fairly sure), later to because a Renesas controller after a driver update.
Since day one the USB3 drive I use with the card has disconnected and reconnected intermittently, resulting in the Windows "ding" sound each time. Not enough to make it unusable, but enough to be a little annoying. I mention this as I've read quite a few forum posts over the years complaining about the same thing.
3 years later my Logitech mouse died. It'd never given me an problem as such before, although the scroll wheel had stopped working reliably and it started dropping out too (even a couple of blue screens I now blame on the mouse), so I replaced. It.
My USB3 drive has now been running non-stop for nearly a week without a single dropout. My USB card reader, which has always been a bit flaky (not always connecting at USB2 speed or sometimes not connecting properly till I reboot the computer) has worked perfectly since I replaced the mouse, although I've only used it a couple of times.
It's odd because I have several USB2 hard drives and they've never been a problem and haven't dropped out as the USB3 drive did. The mouse was plugged into a USB2 port.
Computers.....
Results 1 to 1 of 1
Files corrupted when copying to external usb3 hdd
By kyrcy in forum ComputerReplies: 56Last Post: 7th Apr 2019, 15:28 -
Looking for a new editing computer; what is this problem with USB3?
By ahhaa in forum ComputerReplies: 3Last Post: 15th Dec 2016, 21:50 -
WD 4 TB external disconnecting on USB 3.0
By kenmo in forum ComputerReplies: 31Last Post: 15th Dec 2014, 07:47 -
usb3.0 PCIe card. What brand? which 16 or 32GB 3.0 Flash drive do you use?
By Denvers Dawgs in forum ComputerReplies: 7Last Post: 28th Nov 2012, 11:38 -
1TB usb3.0 drives without power brick questions
By Denvers Dawgs in forum ComputerReplies: 8Last Post: 11th Nov 2012, 15:28
