That's what I said. E.g. avs script:
So, ffms2.dll is x64 and TIVTC.dll is x64 and the x64 VirtualDub, won't open it.Code:LoadPlugin("C:\MeGUIx64\tools\ffms\ffms2.dll") FFVideoSource("C:\jobs\vid.mkv", cachefile="C:\jobs\vid.ffindex", fpsnum=30000, fpsden=1001) LoadPlugin("C:\MeGUIx64\tools\avisynth_plugin\TIVTC.dll") tdecimate() Spline64Resize(1280,720) # Spline64 (Sharp)
But, if you replace both dll's with x32 versions, then the x32 VirtualDub version opens it no problem.
Also, MPC-HC x64 does not render the x64 version .avs neither.
Results 31 to 38 of 38
There is only 2.5.8 MT version for x64 and it's from 2010. Anyway, I followed the instruction in the readme and installed it.
Now MPC-HC tries to load the .avs with CPU usage at 30% for ~10-15 seconds until it gives Cannot render file.
VirtualDub x264 reports that the TIVTC.dll is not a 2.5 AviSynth plugin. But if there's only 2.5.8 version of avisynth for x64? I don't see a 2.6 x64 installer in the official thread. -
Hey that worked. Both Virtualdub and mpc-hc x64 work now. But then again, why all the installers for each version and architecture scattered all over the different forum threads and internet?
Back to original topic. Since everything is working now, yes I can confirm that MPC-HC x64 opens the x64 ffms script instantly with no delay while lsmash has some 2-3 second delay. Same with VirtualDub, there is no delay, instant load for ffms avs and even longer delay for lsmash script.
Today MeGui updated correctly FFMS (2022-4-20 - since long time it failed)...
...wich should i use today (is the day (lol)) ?
FFMS or LSMash for a 3D realtime rendenred video i recorded in a game (SH4, yeah, only first 3D videos were good, game's crap all the way, don't worry i didn't paly it), in RBG (recut frames in VDub too to RGB again) converted to Lagarith afterwards, will it be processed the same all in all ?
For same frames/settings =
AviSource = LSmash (6.5 Mo)
LSMash : 6.5 Mo
FFMS : 6 Mo
HBrake : 4.2 Mo !! (going to use it
VCoder : same...Last edited by Klemc; 6th Oct 2022 at 10:15. Reason: detail - infos processed
LWLibavVideoSource, speeding up load times ?
By vhelp in forum Video ConversionReplies: 15Last Post: 26th Feb 2019, 16:06 -
[avisynth] how to use only FFAudioSource without FFVideoSource
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2015, 15:56 -
[StaxRip] FFVideoSource Can't open
By drundl in forum Video ConversionReplies: 6Last Post: 30th Mar 2015, 05:08 -
How do I use AudioDub and FFVideoSource?
By Baniita in forum Newbie / General discussionsReplies: 8Last Post: 22nd Oct 2013, 02:53 -
DirectShowSource and FFVideoSource Problems
By ndjamena in forum Video ConversionReplies: 15Last Post: 8th Mar 2013, 23:04
