I have Windows 7 64bit, Virtualdub 1.10 and Avisynth 2.6 MT. Virtualdub Input video pane turns green when Virtualdub is the active window. When it's not the active window, image reappears. When I hit play, image reappears. Disabling directx fix this issue but I read this is just a work around. Maybe I need VFW drivers?
In the old days only one program at a time could use video overlay. When you have DX output enabled VirtualDub probably relinquishes video overlay and falls back to Windows GDI when it's not the foreground app. My guess is the color format used in the DX windows isn't compatible with your graphics card. You can try forcing the input colorspace with Video -> Color Depth... Is it all videos/scripts that do this? Or only certain ones?
But there's no good reason not to simply disable DX output these days. In theory, DX output is a little faster. But it introduces other problems like unpredictable color decoding, etc. -
It turns green when it's the foreground/active window. It happens on all scripts. Changing Video -> Color Depth from Autoselect to any other settings fixes it. Hope this is not a workaround.
They're all workarounds. Maybe updating your graphics driver will fix the problem.
VirtualDub status window
By shans in forum Video ConversionReplies: 5Last Post: 9th Sep 2015, 02:15 -
How do I set preview window size in VirtualDub?
By paulot in forum Newbie / General discussionsReplies: 5Last Post: 30th Mar 2015, 17:36 -
Virtualdub output pane showing input video?
By anonymousthing in forum Video ConversionReplies: 10Last Post: 20th Jun 2014, 10:12 -
VirtualDub/AVIsynth to repeat 5 videos until the end of 6th in 6 window PIP
By tat2jr1 in forum EditingReplies: 2Last Post: 2nd Sep 2013, 10:55 -
how can i access to this window without VirtualDub?
By gil900 in forum RestorationReplies: 0Last Post: 5th Apr 2013, 12:27
