Hi guys,
I have been using Amazon's Fire TV stick for some time and I realised it looses internet quite often. One of the reason could be my router is in other room. Essentially, the signal is blocked by TV itself and one wall. I am hoping that if I buy a 2M HDMI cable and move the TV stick to somewhere else, it will not be blocked by at least by TV.
I was looking at HDMI cables online and in shops and I was in shock that the price can range from £3 up to £99 O_o . There is speed parameter like 27Gbps GOLD (£99), 21 Gbps silver (£79), 18 Gbps BLACK (£59) and online cables for £7 on Amazon where speed is not stated. There is also measure of signal degradation, I remember something like 18 dB.
Which parameters are important? Could someone help me to choose on a cable? My TV is semi old but very good and it is not 4K. I am not planning on buying 4K any time soon. Amazon Fire TV is also 2K AFAIK.
I have used several inexpensive 2-meter HDMI cables for 1080p video. All have been fine. A £7 cable should be OK as long as it is labeled as "High-Speed". If a 6 meter or longer HDMI cable was required, you might need a cable with heavier wire gauge than normal or a cable with built-in amplification to get a perfect picture.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
I agree with usually_quiet. I've used many cheap HDMI cables as well, and never had any problems.
Generally, digital interconnects either work or don't work. -
AmazonBasics (or similar) cable should be fine for 2 meters.
https://www.amazon.co.uk/d/Home-Audio-Video-Accessories/AmazonBasics-High-Speed-HDMI-2...ts/B014I8SSD0/Last edited by jagabo; 2nd May 2017 at 20:43.
HDMI to S-Video cable or SCART to S-Video cable.Which is better for elgato?
By VideoFanatic in forum Capturing and VCRReplies: 22Last Post: 23rd Jan 2023, 14:40 -
now rethinking my original plan to run Kodi on Amazon Fire TV
By Seeker47 in forum Video Streaming DownloadingReplies: 2Last Post: 24th Dec 2016, 20:19 -
Network drive video playback on FIRE stick
By efiste2 in forum Video Streaming DownloadingReplies: 1Last Post: 30th Nov 2015, 17:56 -
Amazon Fire TV Discussion Area
By andor1999 in forum Media Center PC / MediaCentersReplies: 10Last Post: 21st Nov 2014, 17:47 -
How to connect pc to TV by HDMI cable if the pc has no HDMI but USB port?
By coody in forum ComputerReplies: 3Last Post: 7th Dec 2013, 06:55
