Hi,
I have a bunch of 10-bit encoded MKV files that I would like to transcode to 8-bit. I once used hi10ptranscoder to do just that, to great effect (it was a simple, straightforward tool with no unnecessary options or shitload of settings to play around with to get what you want: you just had to select the file and then hit the "Transcode" button. End of story), but it appears it is no longer available on the creator's website (the download link leads to a 404 error page), so my question is: is there anyone who downloaded that software, still has it and would be able to share it by any chance? That would be much appreciated!
Thank you in advance for your answers!
I don't but since it seems to be based on ffmpeg you can write a batch file that can do basically do the same. Simply write a text file, save as e.g. "hi10ptranscoder.bat" and drag&drop one or multiple files on it:
Code:PUSHD %~dp0 if [%1]==[] goto :eof :loop ffmpeg -i %1 -map 0 -c:v libx264 -preset medium -crf 20 -maxrate 20M -bufsize 20M -level 4.0 -c:a copy -c:s copy "%~dpn1_[8bit-h264].mkv" shift if not [%1]==[] goto loop
Decrease crf value to make file bigger/better quality. (-3 ~= double size)
Change preset from medium to something else to change speed: ultrafast,superfast, veryfast, faster, fast, medium, slow, slower, veryslow, placebo
https://trac.ffmpeg.org/wiki/Encode/H.264 -
Thanks for the answer!
Seems to be working alright, though even with the "ultrafast" preset, it takes quite a lot of time to transcode the file (more than 20 minutes for a 20 minutes long file). I remember Hi10p Transcoder doing that in just a few seconds (or at least, much more rapidly than with this method), which is why I was looking for it.
So, my request still stands: if anyone has Hi10p Transcoder and would be willing to share it, consider me still interested in it. In the meantime, I'll use your method, sneaker.
Thanks again for your help!
[Solved] Problems playing Hi10p, Green scroll/etc. (MPC-HC)
By gryph1 in forum Software PlayingReplies: 3Last Post: 29th Sep 2014, 19:18 -
megui Hi10p video encoding error
By John Titor in forum Newbie / General discussionsReplies: 2Last Post: 1st Jun 2014, 03:41 -
Are there any good VFW-based video transcoder? (Not the virtual-dub)
By Stears555 in forum Video ConversionReplies: 2Last Post: 9th Oct 2013, 10:35 -
Hi10P Player
By Nobility350 in forum Newbie / General discussionsReplies: 2Last Post: 11th Sep 2013, 21:18 -
Allegro DVT : world first live broadcast encoder and transcoder for HEVC
By david55 in forum Latest Video NewsReplies: 0Last Post: 13th May 2013, 03:12
