I have a ffmpeg batch crop command that handles all files located in one folder and exports them to a folder named "cropped". Everything works well, however I cannot get ffmpeg to handle videos with blank spaces in the title, for example: "this great video.mpeg". Can someone please let me know what I need to add to this command?
Code:for %%a in ("*.mp4") do "C:\FFmpeg\bin\ffmpeg.exe" -i %%a -vf crop=1280:680:0:0 -c:v libx264 -level 40 -pix_fmt yuv420p -preset medium -crf 20 -threads 8 -c:a aac -strict experimental -ar 48000 -ab 256k -f mp4 "cropped\%%~na.mp4" pause
IMHO even quotation not work 100% - this is cmd nature (it will work if you escape every space in name but i don't know if this is possible within cmd) - safer is to not use blank spaces in a files names. You can substitute blank space with underscore - some multirenamer can be useful - i always recommend total commander, alternatively you may use short (DOS) names.
"%%a" is the way to go and as I always stress it is better to call it like call :my_function "%%a" and it becomes %1 within that function, then call it "%~1"
That seems to always work, I could not find a scenario it would not.
Code:for %%a in ("*.mp4") do call :my_function "%%a" pause exit :my_function "C:\FFmpeg\bin\ffmpeg.exe" -i "%~1" -vf crop=1280:680:0:0 -c:v libx264 -level 40 -pix_fmt yuv420p -preset medium -crf 20 -threads 8 -c:a aac -strict experimental -ar 48000 -ab 256k -f mp4 "cropped\%~n1.mp4" goto :eof
windows batch: paste but don't execute command in Windows command prompt
By flashandpan007 in forum ProgrammingReplies: 17Last Post: 22nd Jun 2016, 23:12 -
A small gui to handle batch merges for MKVmerge. (Windows only)
By librarien in forum User guidesReplies: 4Last Post: 14th May 2015, 13:03 -
using the OR command in a batch
By marcorocchini in forum Newbie / General discussionsReplies: 8Last Post: 30th Sep 2014, 17:56 -
DOS batch command variable
By sambat in forum ProgrammingReplies: 6Last Post: 24th Sep 2014, 13:14 -
Command Line Batch File
By agent3lephant in forum Authoring (DVD)Replies: 1Last Post: 28th Apr 2014, 11:24
