So I got a blu ray burner just over 2 weeks ago and didn't have many problems with it at first and the ones i did have involved discs failing the verification and i was told this was due to the types of discs i was using. however in the past week every verification has failed and I have tried with two different types of discs including japanese verbatim discs and tried two different types of software (nero and imgburn). and every disc fails the verification stage and when I go to check the data (films normally) at least one file will freeze up completely at some point and require me to eject. So my question is does this sound like bad discs or have i got a shitty blu ray burner. I really hope its not the later as I brought it as ex display from ebay and it is past the 14 day returns period .
thanks in advance for any advice you can give me
Closed Thread
it is a samsung SE-506 external
just tried it again with all programs closed and this is the burn log:
I 19:35:46 ImgBurn Version 2.5.8.0 started! I 19:35:46 Microsoft Windows 8 Core x64 Edition (6.2, Build 9200) I 19:35:46 Total Physical Memory: 33,504,204 KiB - Available: 30,654,696 KiB I 19:35:46 Initialising SPTI... I 19:35:46 Searching for SCSI / ATAPI devices... I 19:35:46 -> Drive 1 - Info: DiscSoft Virtual 1.0 (L
(Virtual) I 19:35:46 -> Drive 2 - Info: DiscSoft Virtual 1.0 (K
(Virtual) I 19:35:46 -> Drive 3 - Info: TSSTcorp BDDVDW SE-506CB TS02 (H
(USB 2.0) I 19:35:46 -> Drive 4 - Info: DiscSoft Virtual 1.0 (J
(Virtual) I 19:35:46 Found 3 BD-ROM XLs and 1 BD-RE XL! I 19:36:22 Operation Started! I 19:36:22 Building Image Tree... I 19:36:22 Calculating Totals... I 19:36:22 Preparing Image... I 19:36:22 Contents: 29 Files, 1 Folder I 19:36:22 Content Type: Data I 19:36:22 Data Type: MODE1/2048 I 19:36:22 File System(s): UDF (2.50) I 19:36:22 Volume Label: [Not Configured] I 19:36:22 Size: 19,579,019,736 bytes I 19:36:22 Sectors: 9,560,082 I 19:36:22 Image Size: 19,580,059,648 bytes I 19:36:22 Image Sectors: 9,560,576 I 19:36:22 Operation Successfully Completed! - Duration: 00:00:00 I 19:36:44 Operation Started! I 19:36:44 Building Image Tree... I 19:36:46 Calculating Totals... I 19:36:46 Preparing Image... I 19:36:46 Contents: 29 Files, 1 Folder I 19:36:46 Content Type: Data I 19:36:46 Data Type: MODE1/2048 I 19:36:46 File System(s): UDF (2.50) I 19:36:46 Volume Label: Indiana.Jones.The.Complete.Adventure.Collection.19 81-2008.1080p.BRRip.x264.AAC-m2g I 19:36:46 Size: 19,579,019,736 bytes I 19:36:46 Sectors: 9,560,082 I 19:36:46 Image Size: 19,580,059,648 bytes I 19:36:46 Image Sectors: 9,560,576 I 19:36:47 Operation Successfully Completed! - Duration: 00:00:03 I 19:36:47 Operation Started! I 19:36:47 Source File: -==//[BUILD IMAGE]/\==- I 19:36:47 Source File Sectors: 9,560,576 (MODE1/2048) I 19:36:47 Source File Size: 19,580,059,648 bytes I 19:36:47 Source File Volume Identifier: Indiana.Jones.The.Complete.Adventure.Collection.19 81-2008.1080p.BRRip.x264.AAC-m2g I 19:36:47 Source File Volume Set Identifier: 4A9E9C950091E192 I 19:36:47 Source File Application Identifier: ImgBurn v2.5.8.0 I 19:36:47 Source File Implementation Identifier: ImgBurn I 19:36:47 Source File File System(s): UDF (2.50) I 19:36:47 Destination Device: [0:0:0] TSSTcorp BDDVDW SE-506CB TS02 (H
(USB) I 19:36:47 Destination Media Type: BD-R (Disc ID: CMCMAG-BA5-000) I 19:36:47 Destination Media Supported Write Speeds: 2x, 4x, 6x I 19:36:47 Destination Media Sectors: 12,219,392 I 19:36:47 Write Mode: BD I 19:36:47 Write Type: DAO I 19:36:47 Write Speed: 2x I 19:36:47 Hardware Defect Management Active: No I 19:36:47 BD-R Verify Not Required: Yes I 19:36:47 Link Size: Auto I 19:36:47 Lock Volume: Yes I 19:36:47 Test Mode: No I 19:36:47 OPC: No I 19:36:47 BURN-Proof: Enabled I 19:36:47 Write Speed Successfully Set! - Effective: 8,992 KB/s (2x) I 19:38:04 Filling Buffer... (80 MiB) I 19:38:05 Writing LeadIn... I 19:38:39 Writing Session 1 of 1... (1 Track, LBA: 0 - 9560575) I 19:38:39 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 9560575) I 20:03:33 Synchronising Cache... I 20:03:40 Closing Track... I 20:03:41 Finalising Disc... I 20:05:40 Exporting Graph Data... I 20:05:40 Graph Data File: C:\Users\BEAST\AppData\Roaming\ImgBurn\Graph Data Files\TSSTcorp_BDDVDW_SE-506CB_TS02_30-APRIL-2017_19-36_CMCMAG-BA5-000_2x.ibg I 20:05:40 Export Successfully Completed! I 20:05:40 Operation Successfully Completed! - Duration: 00:28:52 I 20:05:40 Average Write Rate: 12,807 KiB/s (2.9x) - Maximum Write Rate: 24,615 KiB/s (5.6x) I 20:05:40 Cycling Tray before Verify... W 20:05:57 Waiting for device to become ready... I 20:06:07 Device Ready! I 20:06:08 Operation Started! I 20:06:08 Source Device: [0:0:0] TSSTcorp BDDVDW SE-506CB TS02 (H
(USB) I 20:06:08 Source Media Type: BD-R (Disc ID: CMCMAG-BA5-000) I 20:06:08 Source Media Supported Read Speeds: 2.2x, 4x, 6x I 20:06:08 Source Media Supported Write Speeds: 2x, 4x, 6x I 20:06:08 Source Media Sectors: 9,560,576 I 20:06:08 Source Media Size: 19,580,059,648 bytes I 20:06:08 Image File: -==//[BUILD IMAGE]/\==- I 20:06:08 Image File Sectors: 9,560,576 (MODE1/2048) I 20:06:08 Image File Size: 19,580,059,648 bytes I 20:06:08 Image File Volume Identifier: Indiana.Jones.The.Complete.Adventure.Collection.19 81-2008.1080p.BRRip.x264.AAC-m2g I 20:06:08 Image File Volume Set Identifier: 4A9E9C950091E192 I 20:06:08 Image File Application Identifier: ImgBurn v2.5.8.0 I 20:06:08 Image File Implementation Identifier: ImgBurn I 20:06:08 Image File File System(s): UDF (2.50) I 20:06:08 Read Speed (Data/Audio): MAX / MAX I 20:06:09 Read Speed - Effective: 2.2x - 6x I 20:06:09 Verifying Session 1 of 1... (1 Track, LBA: 0 - 9560575) I 20:06:09 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 9560575) W 20:15:05 Failed to Read Sectors 3719744 - 3719775 - Reason: L-EC Uncorrectable Error W 20:15:15 Failed to Read Sector 3719744 - Reason: L-EC Uncorrectable Error W 20:15:15 Sector 3719744 maps to File: \Indiana.Jones.and.the.Temple.of.Doom.1984.1080p.B RRip.x264.AAC-m2g.mkv E 20:18:17 Failed to Read Sector 3719744 - Reason: L-EC Uncorrectable Error E 20:18:17 Sector 3719744 maps to File: \Indiana.Jones.and.the.Temple.of.Doom.1984.1080p.B RRip.x264.AAC-m2g.mkv E 20:18:17 Failed to Verify Sectors! I 20:18:18 Exporting Graph Data... I 20:18:19 Graph Data File: C:\Users\BEAST\AppData\Roaming\ImgBurn\Graph Data Files\TSSTcorp_BDDVDW_SE-506CB_TS02_30-APRIL-2017_19-36_CMCMAG-BA5-000_2x.ibg I 20:18:19 Export Successfully Completed! E 20:18:19 Operation Failed! - Duration: 00:12:09 I 20:18:19 Average Verify Rate: 10,219 KiB/s (2.3x) - Maximum Verify Rate: 17,626 KiB/s (4.0x) I 20:20:17 Close Request Acknowledged I 20:20:17 Closing Down... I 20:20:17 Shutting down SPTI... I 20:20:17 ImgBurn closed!
as you can see it failed on verification again
Experiencing a big problem with my Samsung Blu Ray burner
By slaughteredlamb in forum DVD & Blu-ray WritersReplies: 1Last Post: 12th Apr 2017, 22:42 -
Having a little problem with my Blu Ray burner and AnyDVD/DVDfab
By Fantadude in forum Blu-ray RippingReplies: 9Last Post: 15th Dec 2015, 14:07 -
pioneer blu ray burner -want to make 1:1 copies of my blu ray movies
By Cool joe in forum MacReplies: 10Last Post: 10th Dec 2014, 22:31 -
LG Blu-ray Burner problem
By GeoVideo in forum DVD & Blu-ray WritersReplies: 3Last Post: 14th Apr 2014, 10:23 -
Blu-Ray burner wont recognize my Blu-Ray disc, Only DvD dics?
By PurkkaPoika in forum Authoring (Blu-ray)Replies: 5Last Post: 10th Jul 2012, 15:26
